how to replace the exhaust tip
I did a search and didn't come up w/ anything specific on how to just replace the stock black tailpipe tip. It looks like two indentations are pressed against the inner tailpipe. ???? FYI '83 911sc Coupe 3.0 stock single out exhaust.
Thanks,
Don
'93 BMW 325i
Old 07-06-2004, 10:35 AM
MY83SC's Avatar
On my '83 I started by spraying a penetrating fluid. Turning it left and right in 30 minute intervals. I finally used two vice grips and was able to do 360's and work it off.
Mike
83 SC
Old 07-06-2004, 10:39 AM
I'm off the hook.....
My PO decided to weld a new tip on. By the time he had burned the rusty tailpipe material enough to get it to stay, it was 'substancially shorter' than stock. My first purchase was a used muffler with a good tailpipe.
No, I don't sing. Based there for too long.
Old 07-06-2004, 11:01 AM
MY83SC's Avatar
Don't you hate PO's and the things they do? Since I will never sell my car, only my benefitiary will be able rant and rave about me. And I will not be here to hear it!
Mike
83 SC
Old 07-06-2004, 11:05 AM
When I added a second tailpipe to my Carrera I merely drilled a small hole on each side of the inside end of the new tip (the end facing into the engine bay). I then tack welded through the small hole on each side and sprayed a dot of black rustoleum over the tack weld.
Has held up well over the years.
Warren & Ron, may you rest in Peace.
Old 07-06-2004, 11:08 AM
Brillo's Avatar
I used a piece of wood up against the back side of the old tip, whacked the piece of wood with a hammer until it came off.
Ray H.
1979 911SC Coupe
2000 986
Old 07-08-2004, 10:38 PM
I used the vise grip method. Jerked on it for about 20 minutes until I could work it off. Put the new one on in 30 seconds!
Don
'93 BMW 325i
Old 07-09-2004, 12:57 AM
