Cost To Replace Rear Section of Cabriolet Top?
I hear it's possible to replace just the rear window and surrounding fabric of my '88 Cabriolet top, without replacing the entire top.
Is this true and if so, how much should it cost for parts and labor to replace it? Mine has a small tear in the plastic window.
Old 07-06-2004, 08:46 PM
Yes , you can replace the back half but you need to make sure the front half will last as long as your new part . It would be cheaper in the long run to replace the intire top rather than doing it in sections . Why are you replacing just the back half , if it is to replace the window itself you can have new window sewn into your existing rear section depending on condition.
Jim
77S
04 Titan
03 Xterra
Old 07-07-2004, 02:53 AM
3.2 CAB's Avatar
The rear and front pieces have a lot of adhesives that are used on the joint where they meet, I am not sure the fabric would stand up to tearing it apart and then trying to put it back together again, I agree with Jim about replacing the entire top. The cost of just removing the rear section would be almost as much as to do the entire top as it is the hardest part of the new install. I replaced mine 2yrs ago, after I found out how much the shops around here wanted to charge, I did it by myself, it almost drove me insane, a real PITA!!! I am happy with it but is was a lot of work to get it right, I don't know that I would replace it again myself. Good luck.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 07-07-2004, 05:53 AM
Hmm...ok. So all I really need is the rear window replaced. Sounds like that's doable separately. Any idea of the cost for just the window replacement?
Old 07-07-2004, 07:50 AM
Not Quite Banned
Thomas Owen's Avatar
Having done an entire top on an '88 I would agree whole-heartedly with the above comments. Do the entire top if the rear section has a problem.
Good luck,
Thomas Owen
1972 911T
1972 911S
I just had the rear window replaced on mine, cost me $400 p/l. A complete new top would have been ~$1600 p/l.
Old 07-07-2004, 08:25 AM
