Removing Carrera Emblem?
I have an 87 Carrera and would like to remove the original emblem because the PO installed the Carrera tail and the emblem is up too high on the decklid.
This is the original Carrera emblem - I have read that the best way is to heat the area up with a blow drier and use dental floss? Is this really the best way? Will it come off easily without much residue? thanks. |
Friend of Warren
Use dental floss then remove the residue with WD40.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Yep, all of the above...
GruppeB #935 84 Carrera Targa B.A.S.T.A.R.D. (for sale) 82 SC RSR Project (on ebay) 95 Dodge Ram 2500 03 Toyota 4runner |
Don't be surprised if you have to lightly go over the area (and surround) with a very fine polish.
Warren & Ron, may you rest in Peace. |
I did this on my 993 and installed the silver 911 badge. But the "Carrers" still appears in sunlight. Residue is all gone, but I'd like the shadow to go away. How?
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Richard,
You have to make the rest of the lid look as good as the untouched area from under the emblem....or... the other way around ![]() That's why I recommended a fine polish to rub out and minimize the difference. Same thing happens when changing over from flag style mirrors to the smaller footprint Aero style.
Warren & Ron, may you rest in Peace. Last edited by RickM; 07-08-2004 at 11:18 AM.. |
Rob Fusi 77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s | GTC Motorsports |
Certified Pre-Owned
3M Perfect-it III machine glaze (fine swirl mark remover) running 1500 rpm using a 3M fine polish foam pad. Keep the surface wet with compound.
Depending on when the emblem was placed on after the tail was painted, it may never come out...
'84 Carrera Coupe |
