efhughes3's Avatar
Problem at the track today-VERY expensive valve stem!
While in the PCA DE today, I was going into the 3rd lap of my 2nd session, and had a bug surprize. The typical DE track setup at TMS had a chicane at the end of the front "straightaway" prior to NASCAR turn 1. While exiting the chicane, you're moving the car a bit to the right.
My rear end kicked out (quite a surprize), and at first I thought I'd really screwed up the line thru the chicane. I continued on thru turns 1 & 2 and made a 180 degree left to enter the infield. At that point, she was really goofy.
To make a long story short, I had a flat. It turns out my VALVE STEM had split. This caused the air loss, but the tire sidewalls basically were trashed. I was able to buy a non-matching tire at the track, and finished the day. From now on, I'm checking my valve stems more closely when checking air pressure. BTW, I THINK it was the chrome sleeve over the rubber stem that was a little loose, and sawed thru the stem over the 4000 miles it's been on.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 07-08-2004, 03:21 PM
Don't you have the valve stem supports on your wheels?
Old 07-08-2004, 03:49 PM
chrome sleeves and heavy metal caps really stress the stem centrifugally. supports are a must.
206 637 4071
Old 07-08-2004, 03:58 PM
Speaking of which, does Pelican or someone sell the metal stems?
'80 SC
Old 07-08-2004, 04:01 PM
Formerly bb80sc
Vipergrün's Avatar
Ditto
-B
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 07-08-2004, 04:08 PM
I'm off the hook.....
I got mine from Performance Parts. Probably more expensive that discount, but they are the OEM ones.
Their site is their name. The only reason I say this is because I do not think PP has them.
No, I don't sing. Based there for too long.
Old 07-08-2004, 04:15 PM
Non Compos Mentis
The REALLY expensive valve stem is inside your engine. Your misfortune is a relief from what I was expecting.
I'm going to go check my stem supports now......
Old 07-08-2004, 04:37 PM
Stem supports are a marginal solution, especially in the hot weather and at high speed tracks. The best thing to do is install metal valve stems and caps with the seal on the insides of the cap. This gives you an extra margin of safety since the schrader valves can develop their own problems. I'm glad you're Ok!!
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 07-08-2004, 04:44 PM
Zeke's Avatar
Hehe. I thought the same thing.
Old 07-08-2004, 04:47 PM
Gordo2's Avatar
NAPA Solid Metal Tire Valve Stems
Not sure if Pelican carries them. I bought solid metal valve stems from Napa for about $5 per pair. They have a nut that screws them onto the rim (very solid) Can't recall the size (hole diameter) but the smaller diameter/shorter length ones fit well.
I had a little bit of a difficult time installing the fronts on my six's, but they fit with a little coersion (the rim has a sharp angle where the valve stem seats, the washer on the stem winds up slightly cocked between the flat surface and the edge of the rim that protrudes. They fit perfect on stock rear rims.
Good luck, Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 07-08-2004, 09:14 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
I just had to rotate the photo.
Old 07-08-2004, 09:19 PM
efhughes3's Avatar
Thanks guys-metal stems it is! Sorry for the misleading title.
Ed Hughes
2015 981 Cayman GTS
Old 07-09-2004, 03:53 AM
Senior Member
Has anyone used the stems that sit flush to the wheel. To check pressures or add air you had to screw in a stem and when done you unscrewed the stem and capped it off.
Nothing to flex or fatigue
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 07-09-2004, 05:09 AM
kqw kqw is offline
If you install the valve stem savers, wouldn't you have to re-balance your tires?
The Fox
Carrera
Old 07-09-2004, 07:27 AM
}{arlequin's Avatar
If I'm using the regular lightweight plastic stem/cap, am I still going to have the centrifugal problem? I've never had this problem on any other car I've tracked/driven...
dave
1973,5
Old 07-09-2004, 08:23 AM
KNS KNS is offline
Is there any thing wrong with plain 'ol plastic caps?
Kurt
Old 07-09-2004, 12:33 PM
MBruns for President
JeremyD's Avatar
Sorry I missed you - I did the PCA DE on Wednesday - driving the banking was pretty wild - as was the 130mph before the chicane!
Old 07-09-2004, 12:36 PM
I think you need the supports whether you have plastic caps or not. They come from the factory for a reason. It seems to me that on a car with 16x6 and 16x7 they only come on one end, but I can't remember which end. I had metal caps on my car for quite some time, but then I noticed a spot on the wheels that didn't have the supports where the cap would touch the wheel so I changed to plastic. The metal is probably better.
I would think you could have taken a file or grinder to the washer on your metal valve stem, filed a small flat spot, and gotten them to sit flush.
Old 07-09-2004, 12:49 PM
efhughes3's Avatar
Jeremy: Ditto on not catching up with you. That stretch after coming out of # 4 is pretty fun-head toward the wall, and then do the chicane. They had a couple of cars wreck there last year at the Club Race.
Ed Hughes
2015 981 Cayman GTS
Old 07-09-2004, 01:18 PM
Bill Verburg's Avatar
You need to use the short metal stems w/ metal caps w/ an inner seal, like this
At speed the unsealed caps have been known to leak
Bill Verburg
Old 07-09-2004, 02:20 PM
