Toggle switch under dash ??
Today I discovered a toggle switch under my dashboard located under the speedometer.... any clues as to what it is ?? TIASmileWavy
can you take a pic?
This might be the extra solvent for your windshield. MY 89 25th had this too , i think it was in the same position.
jpc |
Might be a kill switch or alarm added by the PO?
Passenger ejector.
Looks aftermarket , i'll go with kill switch too.
jpc |
I like the passenger ejector theory... I'll test it out tomorrow on my wife hehe
Mute button for the "back-seat driver" on the passenger side?
Does it disable the ignition or cause the car to shut down?
Unknown switch
I have one exactly like that. And I added it: it's a front oil cooler fan switch.
George |
that looks like a trunk monkey activation switch to me
Re: Unknown switch
It may also be
You may want to see if it kills the speedometer.
Cool collar activation switch?
Looks more like a heater control switch for a cup-holder...:rolleyes:
Randy |
Primary power for the flux capacitor.
"Today I discovered a toggle switch under my dashboard located under the speedometer.... any clues as to what it is ?? TIA"
Well, I really don't think it will ignite anything, so go ahead and switch it ON (or OFF), then tell us what happens. Don't you have to give US some clues? Sherwood PS: A search in the archives might give you some clues. |
Problem solved !! Thanks Sherwood, I did just what you said and it IS the front oil cooler. I could hear the fan before I turned it over and it would stop when I flipped the switch. Thanks to all for the comments. Jer
JerDe,
Not at all. In compensation, you can give me a ride in your 930. I can man the switch. Sherwood |
| All times are GMT -8. The time now is 07:51 AM. |
