I recently bought a 1981 sc with about 50,000 miles. Runs great most of the time, however I have a couple of questions:
1. When it's first started it idles pretty high, around 1800. Then as it warms up it starts oscilating between 900 and 1800. This goes away after its driven for a few minutes, then it idles around 800 or 900. Is this normal? 2. If I drive the car to the store or where ever and leave it parked for 30 minutes - 1 hour it starts up but will stall if i dont give it some gas. It will continue to stall if i let the rpm come down too fast at a light. But will stay running if i slowly let the rpms fall. I know this isnt right but i'm not sure what it is. here's a pic
Sounds like the WUR (warm up regulator), but Hey, what do I know!?
Mike Searching for a new ride '04 VW GTI 1.8T RIP ![]() '76 911S 3.0 RIP ![]() http://www.pelicanparts.com/gallery/BanjoMike |
i vote WUR reg too!
get the CIS tester gauges, and we can find out for sure. damn nice car. lovin the 81SC lately!
poof! gone |
Designer King
What the others said, plus your mixture may be too rich. This could be because of the WUR, or it could just be set wrong.
Paul
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
I had a simular problem, adjusted the mixture about an 1/8 turn ( if that)counterclockwise and it went away after a couple of days of hard driving.
thanks gus, ill try that
WUR cold control pressure is off. And, your idle mix is off.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
thanks to everyone who responded, it seems to have been the mixture, and with 1/8 turn ccw no more stalling.
Run some chemtool B-12 in you tank a few times. It will clean up the fuel system. Make sure you don't have any rust or garbage in the tank. The WUR is also a good place to start.
1975 911 Carrera BLK/BLK |
