on-ramp's Avatar
Front bumperettes off on 911T
OK, so how do the front bumperettes come off? i looked behind but there's no access to anything. anyone know?
Old 07-12-2004, 05:23 PM
I love this board, I was just going to post the same question!! I dug around under the car and wound up scratching my head, some kind of magic I guess!!
Old 07-12-2004, 05:27 PM
Carbon Emitter
jkarolyi's Avatar
Just did it. You have to remove the front bumper first...kind of a pain in the arse! Two bolts on each side accessed under the hood latch panel near the battery boxes. Then one more bolt that mounts the bumper to the fender, accessed through each wheel well.
Once bumper is off, four torx bolts must be removed...suggest dousing in PBlaster due to almost certain corrosion. Are you both trying to get the bumper-guard-less look? I just ordered the one-piece trim that allows this. Best of luck!
Nice color by the way...what is it?
Old 07-12-2004, 05:54 PM
Yes, nice colour. Lets see more of your car!
Old 07-12-2004, 05:57 PM
on-ramp's Avatar
jkarolyi
which trim would that be? does Pelican carry it?
btw, the color is olive.
Old 07-12-2004, 05:58 PM
on-ramp's Avatar
since you asked, how can i refuse?
Old 07-12-2004, 06:11 PM
Carbon Emitter
jkarolyi's Avatar
That car is SCHWEET!!!!
Your bumper trim will have holes in it from the guards, and mine were chewed up where the guards had been.
Pelican only sells an expensive kit that includes stuff you don't need. I found mine at EuroEast (www.used9parts.com). I got the trim and a set of nice used chrome rear guards for $75. My car had all of it's chrome trim blacked out (ARGHH!!!) and I'm bringing back the chrome look.
Administrator
Jack Olsen's Avatar
Pelican sells a 'deco trim kit' in the S or economy widths. I don't know if they sell just the front piece. I'd call and ask.
With the bumper guards, is the rubber front trim cut, or does it just tend to discolor from lack of exposure to the sun?
Carbon Emitter
jkarolyi's Avatar
Both...there will be a hole drilled in the middle of the trim for each guard.
Old 07-12-2004, 06:15 PM
Do you have to remove the bumperettes to take the rubber trim off or can you just slide the trim out? I hope it is just a simple slide because I don't feel like removing the whole bumper just to get to a nicked piece of rubber trim.
Chris
1986 930
1972 911S
1970 911E
Old 07-12-2004, 06:42 PM
Todd Simpson's Avatar
I took these off my '71T years ago and did not have to remove the bumper. Poke around the front of the trunk and look for access holes.
Old 07-12-2004, 07:04 PM
limble's Avatar
On-ramp did you just get that car? It was in the 911T.org gallery and someone was asking me if I knew who owned it. Was that you?
Thanks,
Mike
When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE.
1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation)
Old 07-12-2004, 07:39 PM
Licensed User
Shuie's Avatar
Thats a great color. Please post some pics after you get them off.
Old 07-12-2004, 07:40 PM
cassidyp's Avatar
I even thought about filling the strip mounting holes and not re-installing the center trim panel. I could also just leave the holes there and go for the really light weight look. IMO I like the front bumper without the pads. Also FWIW my trim piece (72 T) does not have holes from the bumper brackets.
72 911 Targa VTK Member 110245
71 911 Targa
68 911 non sunroof Coupe
Gruppe B # 3911
http://www.pelicanparts.com/gallery/cassidyp
Old 07-12-2004, 08:17 PM
cnielsen's Avatar
If you look in your trunk you will see some white plastic plugs that are a little bigger than a quarter. Simply remove those and there will be two bolts underneath that will enable you to remove the bumperettes. You will see once they come off if your "S" trim was cut underneath the bumperettes or if they were installed over the trim with out cutting.
Good luck, BEAUTIFUL car!!!
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 07-12-2004, 11:47 PM
Gon fix it with me hammer
svandamme's Avatar
the car looks pretty much stock to me and in great shape, sweetness beyond regular sweet... treasure it.... it's a beaut
Stijn Vandamme
BIMDIESELBMW116D2019
Old 07-13-2004, 12:00 AM
OK, same vein of thinking....
I'm going to paint my 67, and would prefer no bumperettes....it appears the thing to do is remove them, and the trim, before it goes to the paint shop, yes?
ditto for the rear?
thx
td
Old 07-13-2004, 08:13 AM
