nreed's Avatar
cylinder head temp sensor placement
I am rebuilding my 86 930 and am thinking about installing some temperature sensors on my cylinders/heads. Where are the strategic locations? Is there an advantage to more than one sensor (ie. on cylinder 2 and 5?)? I assume that an inexpensive thermistor will work fine and what is the best way to attach a sensor? Is high temperature hookup wire like teflon necessary?
Norm '86 930
AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL
HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear)
Old 02-06-2004, 12:09 PM
vash's Avatar
i know the two stroke karting guys have a simple head temp system. i dont know much about it. maybe you can search there? sorry i am not more help.
cliff
poof! gone
Old 02-06-2004, 02:14 PM
scottb's Avatar
Just thought I'd throw this out...
Aircraft engines are generally aircooled. Some are turbocharged. Maybe you should look at places like Chief Aircraft or Aircraft Spruce for ideas.
Good luck, and let us know what you find.
1984 Targa
Old 02-06-2004, 02:19 PM
I'm off the hook.....
The VDO system I use has a temp sensor that installs at the spark plug. I use the #2 cyl. Works good, lasts a long time.
No, I don't sing. Based there for too long.
Old 02-06-2004, 02:43 PM
Bill Verburg's Avatar
cylinders 3 followed by 4 are where issues generally arise
Bill Verburg
Old 02-06-2004, 02:55 PM
I might have the cyl # wrong. I use the middle left side cylinder.
Old 02-06-2004, 05:13 PM
Norm I was going to use my Autometer Pyrometer in conjunction with ‘5248 cylinder head temperature spark plug probe’
http://hp.autometer.com/products/accessories/pyrometer_accessories/pyrometer_accessories.html
Old 02-06-2004, 07:03 PM
Early_S_Man's Avatar
Porsche Crest
Norm,
The aircraft gauges typically use thermocouples ... either under-the-sparkplug or pipe-thread type sensors.
There was quite a discussion of cylinder-head temperature gauges in the following thread:
Have I done any damage?
In addition ... I failed to make a good case for the use of the military surplus Lewis Instruments gauge by not mention that it was designed to work on either 24 Volt or 12 Volt electrical systems ... all you have to do is supply 12 - 14 Volt power at the appropriate terminal! Two Type K thermocouple probes from Aircraft Spruce is all I needed for a functional dual CHT gauge -- for under $100! There is a nice location for it on an old SC console assembly bought off eBay.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-07-2004, 01:32 PM
nreed's Avatar
Thanks to all of you. I've got some good ideas now!
Norm '86 930
Old 02-09-2004, 05:33 AM
nreed's Avatar
p.s.
I now know that Westach (and probably others) sells thermocouple sensors that mount under the spark plug. I'm going to monitor all 6 cylinders with type J sensors, a dual CHT gage and a 3 position switch. It might be overkill but maybe not.....!
Norm '86 930
Old 02-09-2004, 06:42 AM
Randy Webb's Avatar
"cylinders 3 followed by 4 are where issues generally arise" because of the ari flow limitations.
Also, note where PAG put the sensor on the 3.2L engines.
Good luck.
Old 02-09-2004, 10:34 AM
}{arlequin's Avatar
Warren,
Do you happen to see any part numbers on that gauge? Every aircraft place I've checked is asking for a part number.
Thanks.
dave
1973,5
Old 07-16-2004, 07:05 AM
Randy Webb's Avatar
I'd like to know the p/n too. It's a lot funkier looking than my data logger....
As a long-time thermistor hater, let me just advise the original poster to either use the VDO setup or go with thermocouples. Omega is the big boy for selling all sorts of temp. measurement stuff.
Old 07-16-2004, 04:38 PM
scottb's Avatar
This should provide you plenty of information: Chief Aircraft
They even have a kit with six probes, and a gauge the can be switched to monitor the temp on all of the cylinders (one at a time). It's part number EI E6.
1984 Targa
Old 07-16-2004, 04:53 PM
Old Member
Scott B and Norm Reed have a good idea with the ability to monitor all six cylinders. I used a 6 cylinder digital CHT guage on my aircraft as an inflight engine analyzer to make sure (amoung other things) that all my injectors were performing properly, small aircraft engines don't have any computerization and are manually leaned or richened during flight.
A similar CHT package would make a great monitor or analyzer for any of the 911 engines especially injected models. Properly monitored it should reveal a long list of potential probelms before damages result (like a leaking cylinder to head mating surface when a stud fails, resulting in a cooler cylinder in relation to the others).
Clifton Brown
https://www.mancalamarketing.com
Old 07-16-2004, 05:08 PM
