915 output flanges - please help me set this up for my 915 swap
I'm replacing an early '75 915 (915/40) with a later transmission (915/62). The output flanges on the old trans. are the 4-bolt M10 coarse spline type. The CVs measure 110mm.
The outputs on the new 915/62 are 6-bolt, 100mm, fine spine. So my quesition is, how do I make this work? Should I replace the entire CV->axle->CV->wheel hub stub assembly? If I do this, can I use my existing wheel hubs with new, later axles? Or, can I just get two new 100mm, 6-bolt CVs, and mount them on the transmission side to my old axles and bolt them up to the 6-bolt transmission output flanges? Any help very much appreciated. I can't wait to get back on the road. I've been driving a '91 Jeep for 6 weeks!
993 |
I would rather be driving
You should be able to use the correct CV for the hub side, the correct CV for the 915 side and install them on one axle. The other option is to swap hubs on the trailing arm. HMM you can't do that with the 930 transmission. The hub width is too wide.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Could you use the o/p flanges from the old gear box and put then onto your new gear box?
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
Thanks for the replies.
I can't use the old output flanges because they are coarse spline and don't fit into the diff. of the new transmission. I'll try getting two new 100mm 6-bolt CVs, one for each axle at the transmission side, first. If I end up having to get new axles and stubs, does anyone know if the stubs that go through the wheel hubs are all the same for the 915 cars? Or are there fine and coarse spline to worry about there too?
993 |
Try not, Do or Do not
The way to cure this problem is to buy 930 transmission output flanges. They are 6 bolt but they are 10 mm like your CVs. Now you just machine two of the holes on the flanges to fit the pins on your CVs.
That's it. What you will have is a 4 bolt flange with fine splines. to fit your late 915. We have both stock 930 flanges and flanges modified for this conversion in stock. 930 flanges are not cheap but this is your best fix.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Colin, I'm interested in the Route you go as I'm in the same boat. I am dropping a 3.6ltr with a later 915 in my '74 which had the 4 bolt flanges. I figured a 6 bolt flange stub axle would interchange but I don't know for sure. Hopefully somebody will reply to this. Then I would need the stub axles and the axles with CV's that go with the newer transmission that I am shopping for. MGH
This happened before I saw Henry's post, which sounds like a great (maybe the best) solution. Anyway, I'll be fitting these SC axles to my existing wheel hubs, so we'll see about the stub axle question. It's amazing that there isn't more information on the forum about this, as I know there are quite a few similar conversions out there. I've searched and searched, but I haven't found a definitive answer about the stub axles yet.
993 |
Stub Axles
Colin, did you get 6 bolt stub axles with the SC axles? MGH
Yes, new 6-bolt stubs.
993 |
The 100mm-diameter CVs are a bit thicker than the 110 mm CVs (top), but overall length of the axle-stub assembly is identical
993 |
Stub axles (aka joint flange) -- P/N's from PET:
1969 -- 901.332.209.10 -- "Loebro" -- MG 3; SG 5; Illus. 305-00 1969 -- 901.332.209.12 -- "Loebro" -- MG 3; SG 5; Illus. 305-00 (2nd page) 1971 -- 901.332.209.15 "Loebro for chilled cast" 1971 -- 901.332.209.21 "Loebro for pressure casting" 1973 -- 901.332.209.15 "Loebro for chilled cast" |
Overall length
Colin, are the SC axles slightly shorter to make up for the thicker CV Joints? If the joints are 10mm thicker, together that would be almost 1" longer than the old ones(10mmx2). Thanks, MGH
Come on guys
If you use 930 out put flanges (easily modified), the stock, early CVs and axles fit and you get the larger, stronger CVs. Better and more cost effective and no calculations as to fitment. The rest of this exercise seems somewhat futile.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 07-23-2004 at 07:55 AM.. |
Re: Overall length
If the 110mm CVs are indeed stronger then the 100mm CVs, I wonder why Porsche downgraded this part? This is a more trivial point, but there's something to be said for getting the 6-bolt units from a maintenance perspective - those smaller bolts are so much easier to torque, and the axles is so much easier to remove without dealing with the two rollpins.
993 Last edited by cowtown; 07-23-2004 at 08:25 AM.. |
Re: Re: Overall length
You might notice that they went back to the larger CVs on the 930, my guess, they thought they were stronger. As for ease of maintenance: once every 75k miles ?
