Rear Tire Size Pros/Cons - Advice Please
Car is an '88 Carrera.
I have a set of 7X16 and 8X16 Fuchs at Al Reed's right now, getting refinished. I'm going to have Tire Rack drop-ship a set of Yoko AVS ES100s to him. I'm going to use the stock tire size, 205/55 on the 7X16s for the front. I'm trying to decide whether to go with the stock 225/50s on the back, or switch to 245/45s. I've searched and found a bunch of pics of carreras with the 245/45s on the back and they look a little small, diameter-wise, compared to the fronts. They're only 1/2 inch shorter but it's a visible difference. But I like the extra tread width of the 245s (over an inch). Obviously, I'm suffering from my normal excessive fretting and terminal indecision, so I give up. What do you guys think? Thanks! Dave Option: go to a lower profile front tire (205/50) with the 245 rears?
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. Last edited by Wavey; 03-12-2004 at 01:25 PM.. |
drag racing the short bus
Well, the smaller diameter might help the gearing a bit. I think I'd stay with the 50 series you had earlier. Their 225 size is correct for an 8-inch rim. 245 is sort of wide IMO for 8 inches.
The Terror of Tiny Town |
For looks the 225/50 may be ok(if you like that sort of look, I don't)
For performance the 245/45 is the ticket. lower the car if the gap is too big.
I guess my dilema is the visual difference front-to-rear if I go with the 245s. Thanks...
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
Wavey, if I were going to use the 45-series tires, then I'd go with 50s up front. I think the discrepancy between 55 and 45 might be just flat out strange looking - like a dragster in reverse or something. It stretches the aesthetic.
Schleprock
Here's an idea.
If you don't like the fat sidewall look of the fronts, then change those. Go with a 205/50-16 or 225/45-16?
Kevin L '86 Carrera "Larry" |
Here's a pic for reference, with I believe 205/55s up front and I know 245/45s on the rear (my appology to whoever's car this is - not trashing your car, just a personal preference issue):
tire sidewall height
245 x .45 = 110.25 mm 225 x .50 = 112.50 205 x .50 = 102.50 205 x .55 = 112.75 50's are too small on the front. the 55's match either of the two rears wrt to sidewall height. my pref is for the 245's.
'83 930 |
Side wall height is not a critical issue. Most cars are set up for close to equal rolling radius though. Variations of an inch are quit common and acceptable. 205/55 or 225/50 or 225/45 are alkl god 16" matches for 245/45 7" or 8" +23.4mm o/s fronts and 8" or 9" rears are good, wider is better.
FWIW - factory 930 uses 205/55/16 in front on 7" rim and 245/45/16 on 9" in the rear. I know many on the track uses 225/50 in front but if its for street use, I think the benefit may not be noticeable at all.
Don't forget rim width also comes into play here. A 225/50 front with 7" won't give you much increase in contact patch compared with 205/50. Ditto with the rear.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
For those of you in this thread - could you please show your pictures of wheels and tires other then Fuch?
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
Here's 245/45 rear with 205/55 up front but riding lower than the white 911. The tires are Bridgstones SO3's.
I just measured and the sidewall and the 245/45 is about 3/16's shorter from the ground to the wheel lip than the front 205/55 with a full tank of gas and correct air pressure. Edit: the tires in the rear are newer than the fronts, but the tread depth is close on front and rear.
UFLYICU
9's in back. They look identical to the 8's from the outside. The extra inch is inboard. The 245/45/16 most closely matches the factory circumference for speedo accuracy.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Wow, excellent responses! I'll have to digest this for a while. I'm mainly looking to get similar sidewall heights front and rear, not as concerned about the actual aspect ratio. But wider is better on the back, so...
Bob's Flat Six - that could be my car, Dansk and all, except for the headlight rims. Sweet! The guys on this board are the best. It's great to post such an anal question and be understood.
Check out this site:
Tire Calculator Nice little applet that allows you to compare tire sizes and get sidewall and diameter measurements.
Chris M 1985 911 Carrera w/ 3.6 |
oooohhhhh that picture of the black center fuch give me the chills - just what I will do on mine -
Pretty cool site , Chris
Here are various fuchs on my car for comparison:
205/55 front on 7x16" 225/50 front on 8 by 16" 951 rim 225/45 front on 8 by 16" 951 rim 245/45 rear on 9 by 16" rim
I have 245/45s on the rears (9s)...and 205/55s on the fronts (7s).
The 245/45s do look a little thin and definately added much space to the rear wheel well. The car now needs to be lowered for sure. If I had to do it all again, Id choose 245/50s for the rear. You will love the AVS ES 100s btw.... |
