what is that thing of the day
Hello!
I have another what is that thing that I want to run past you. at the left back of the engine, I have that a pipe which is disconnected and that I can not reconnect because the pipe it connects in is more or less dead. Can someone identify this pipe, what it's doing, and what is going to be done wrong if it is not connected. the car is a 1980 911 SC. the pipe is located next to the connection for the o2 sensor (see picture) and is connected on the other side to the CIS/air box stuff (I do not know how to describe it better), but look at the picture (it's the air intake on the right). you can see better pictures at: http://hpmad.homeip.net/what%20is%20that/big.html Also, I created an easy o2 connect/disconnect stuff, see: Thanks, cyrille |
Looks sort of like the vacuum line for the brake booster
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
It's either that or an emissions hose. See if it goes to the Charcoal canister.
78SC coupe, Silver Metallic |
If the hole goes into the airbox ( plastic protrusion from the airbox, not steel) it's an emissions hose to the Char Can.
hello
On my 83 SC, that port off the air box goes to a port on top of the cruise control tempomat in the corner between the firewall and the fuel accumulator. If it was open, it would be a considerable vacuum leak.
Jim Dowty 97 911 Coupe (Forest Green metalic, sunroof, leather) PCA RSR region Insurance chair and Board member Gruppe B #309 |
hello
