LinkBack Thread Tools Rating: Thread Rating: 1 votes, 2.00 average.
This is what a Hella H4 install looks like:
Chris M
1985 911 Carrera w/ 3.6
Old 07-27-2004, 12:08 PM
Chris.... now I am totally lost. I thought those rings are the original. Do you have US or Euro H4's?
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 07-27-2004, 12:10 PM
Those are Hella H-4s, usually referred to as "US" H4s. Here's the deal:
H-4 is technically the bulb, not the assembly. There are two style of headlight assemblies that us H-4 bulbs that we can put in our cars.
The first type is the Bosch H-4 assembly, commonly referred to as the "Euro" H-4. This is what creaturecat showed in his post earlier in the thread. This assembly replaces EVERYTHING in the headlight bucket.
The second type is the Hella H-4 assembly. This is a replacement for the sealed beam headlights US spec cars had prior to 1987. The Hella assembly replaces only the sealed lightbulb itself - the trim rings, headlight holder, etc, are kept. This is what I show on my car in the picture above. Hella H-4s with my original, old style US spec trim rings.
H-5s are the lights US cars got in 1987. They look similar to the Euro H-4 assemblies, but use a different bulb. If you are only after looks, H-5s look almost like Euro H-4s, so no need to change. If you want more light, you need to replace the entire H-5 assembly with a Bosch (Euro) H-4.
Chris M
Old 07-27-2004, 01:02 PM
steve911's Avatar
Originally posted by 88911coupe
John, Could you shed a little more light (no pun intended) on this Hella option? I thought if I "upgraded" to H4s I'd have to install a relay and this never looked too simple, at least not for me.
TIA
Buck--
The addition of relays to the headlight circuits is one of those that should be done irrespective of what headlamps you have. Without relays, the current is going through the stalk on the steering column and it will fail - just a matter of time.
Installing the msucro relay kit ($20 or so) is very, very easy - an advanced degree in electrical engineering is definitely NOT required. The kit comes with well-documented, easy to understand instructions.
Do a search on msucro or sucro and you'll find loads of threads, complete with pictures - there was one not too long ago.
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 07-27-2004, 02:06 PM
Thank you Chris M for ...putting the light on the subject ....so to speak.
I guess what I am after is the H4 euro, for more light.
The issue currently is a small chip in each H5 lens. The cost of lens replacement alone lends itself to an upgrade accordingly.
Old 07-27-2004, 03:29 PM
KCPSG's Avatar
ken_xman I am in the same boat, I have a small chip in the RF headlight lense and after reviewing costs it seems worthwhile to go w/the upgrade. However I am not keen on the idea of having a black or chrome lense ring on my all white car. (black wouldn't be so bad) but I would rather have the ring the same color as previous ring......I believe the prices were $129 for the H5 and $147 for the H4 what a conundrum.
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 07-27-2004, 03:41 PM
david914's Avatar
In case you didn't know (forgive me if you do), the black lense ring is "paintable", meaning, it's meant to be painted to match your car. What most do, is buy the chrome ringed H-4's and get the paintable trim rings that cover the chrome part. Works great.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 07-27-2004, 03:53 PM
I have an 80 SC that someone added Bosch euro H4,s . They have chrome rings but with an extra countersunk hole dead center at the top. Does anyone recognize what these are Perhaps early 60,s ?
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 07-27-2004, 06:19 PM
frankc's Avatar
Here's a pic of my H1's. Notice the separate smaller reflector on the bottom.
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 07-27-2004, 06:37 PM
There is still some confusion here. Jazzbass has a good summary.
Pre 87 cars have the heavy, "sugar scoop" trim ring and use ( for the US market) sealed beam lights. You can simply replace the light with Hella H4 and leave it at that. Let's not get into the habit of calling these US H4's as there are no US legal H4's of any kind. OR....you can replace the entire light assembly with aero looking Bosch H4's.
Caution: for 87+ guys with the H5's....if you go with Bosch H4's, you will also need to replace the PLUG on the car's wiring. Thr pin pattern is different with H4 and H5.
Wil
EDIT:
On another post I was reminded that there are (now) 2 styles of Hella replacement H4's that replace the US sealed beam units...as pictured in Jazzbass pic above:
- the Hella H4 I talked about that uses a replacble H4 bulb and has no aiming teets...this glass lens is classic 'euro' in performance, and
- a newer version from Hella that is indeed DOT certified. This means it has a H4 lens inside ( not replacable separate from reflector), has the aiming teets...but also has the awful DOT-approved cut or flutes on the lens that mimic US style lenses.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 07-28-2004, 05:01 AM
Banned
fastpat's Avatar
An excellent thread deserving of a bump. I plan on the H4 conversion for my 1988, and this answered every question.
Old 06-04-2005, 08:25 AM
beamonk's Avatar
Send a message via AIM to beamonk
How do the H-1's work compared to the H=4"s?
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 06-04-2005, 01:30 PM
efhughes3's Avatar
Some prefer the H1s over the H4s, they are certainly much more money. When I bought my car, I was looking into H4s assuming they'd be better, and a respected Porsche place here in Dallas suggested I stay with my H1s.
Having said that, I don't know how they compare side by side. I will say I'm pretty happy with mine.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 06-04-2005, 02:21 PM
randywebb's Avatar
I've compared H1s and H4's sequentially by driving to a marked spot on a level road where there are several hwy signs at different distances. I couldn't find any differences. OTOH, I didn't play around with the H1's to tune in the max range I possibly could. Also, there might have been just a tad of fog - I couldn't really tell. I was surprised...
As usual, people have all sorts of opinions but never test them. So here is a test...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-04-2005, 02:42 PM
Can't I just replace the bulb of my 87 H5's with a brighter bulb? Like the blue bulbs? Or am I totally of base here?
Old 11-15-2005, 08:58 AM
fuelie600's Avatar
Or you could watch the classifieds for used H5s from someone who bought H4s....
Evan
1987 sun roof coupe
Old 11-15-2005, 10:05 AM
Its been a year since I started this post ... and still have the chipped lenses. Gives it character.
Old 11-15-2005, 10:15 AM
Banned
fastpat's Avatar
Sylvania Silver Stars will brighten up stock H5's and not burn up your wiring and bulb holders. If you want more light, then H4's are your best answer without going to the trouble and expense of a genuine Xenon system.
Old 11-19-2005, 06:42 AM
...looks like a tougher conversion....
I have an '86....but it must be either a later '86 or had a dealer aftermarket conversion to the H5's because I don;t have sugar scoops....so I'm going from H5's to H4's which is not quite the "ten minutes and a screwdriver" install that some vendors promise. So my question remains " can use my H5 rings for H4's..
and :what do I need to convert the plug from H5's to H4's? Anyone done this lately?
Old 06-14-2006, 12:18 PM
Banned
fastpat's Avatar
Re: ...looks like a tougher conversion....
No, the trim rings on the H5's won't fit theH4 Hella units. The H4 units look a lot like the H5's, but are enough different to preclude direct swapping. Most folks get the primered(black) H4 trim ring and have it painted to match the car.
See: http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_ELlite_pg1.htm click on photo two.
Old 06-15-2006, 02:58 AM
