ICD ICD is online now
Are these compression numbers OK?
140 on five cylinders, 150 on the 6th. Is this OK? What is the acceptable range?
How is a 6 - 8% leak down test on all cylinders. Is that OK?
Old 07-26-2004, 11:49 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
don't know about leak down but your compression numbers are just fine. They should be within 10%
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 07-26-2004, 11:55 AM
Designer King
Paulporsche's Avatar
Both are good.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-26-2004, 11:57 AM
Friend of Warren
On a leakdown, ideal is less than 5%, over 5% and something is showing some wear.
Kurt V
Designer King
I was just about to edit my response when Kurt logged in. 5% or less is best. How many miles on the engine? If you have 100k or more, I think 5-8% is to be expected.
Paul
Old 07-26-2004, 12:04 PM
Grady Clay's Avatar
ICD,
Where are you located? Altitude makes a large difference in compression measurement.
Kurt, Tim, and Paul are right on.
Everyone should record these measurements on a regular basis for a baseline for your engine. How do you know you have, or are developing, a problem if you don’t know the history?
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 07-26-2004, 12:12 PM
The car in question is an '87 Carrera. The car is in Kansas City. It has 115k on it., but it had a valve job around 55K.
The bottom line question is this:
Will this car need valves or rings any time soon with these test results?
Old 07-26-2004, 01:06 PM
Friend of Warren
No guarantees, but probably no.
Kurt V
Old 07-26-2004, 01:08 PM
