-   -   Injection system cleaner. (http://forums.pelicanparts.com/porsche-911-technical-forum/174944-injection-system-cleaner.html)
76911S 07-29-2004 07:48 AM
Has anybody had good success with using an additive in the fuel tank to help clean the injection system, especially if the car has sat for a while? If so what brand is recommended?
Thanks..
DavidI 07-29-2004 08:02 AM
Several people have recommended Techron. I used it and it seemed to work well.
Good luck, David
juanbenae 07-29-2004 08:26 AM
http://www.seafoamsales.com/motorTuneUp.htm
in a recent search for the same product i heard this stuff was the bomb. i had already used the techron product because a clogged injector caused a check engine light to come on. guys on a toyota truck board swore by it and a thread i posted here some of the guys here gave a positive vote.
juanbenae 07-29-2004 08:27 AM
here>>> http://forums.pelicanparts.com/showthread.php?threadid=172234&highlight=seafoam+n ot+the+color
mb911 07-29-2004 08:35 AM
AMSOIL PI works well to
Ben
Jeff Alton 07-29-2004 08:50 AM
I use techron fairly regularly and only Chevron gas. When I tore my 3.2 down, the valves were "clean as a whistle"
Jeff
88911coupe 07-30-2004 09:22 AM
I found some Sea Foam but need a suggestion on how to get it into the system. It says to use the PCV or something to draw it directly into the intakes but I'm not sure what to do on an 88 3.2...any suggestions?
TIA
CARRERIC 07-30-2004 03:52 PM
Berrymens Chemtool B-12. Change oil after a couple tanks.
