Injection system cleaner.
Has anybody had good success with using an additive in the fuel tank to help clean the injection system, especially if the car has sat for a while? If so what brand is recommended?
Thanks.. |
Several people have recommended Techron. I used it and it seemed to work well.
Good luck, David
99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) |
Banned
http://www.seafoamsales.com/motorTuneUp.htm
in a recent search for the same product i heard this stuff was the bomb. i had already used the techron product because a clogged injector caused a check engine light to come on. guys on a toyota truck board swore by it and a thread i posted here some of the guys here gave a positive vote. |
Banned
here>>> sea foam, not the color
AMSOIL PI works well to
Ben |
I use techron fairly regularly and only Chevron gas. When I tore my 3.2 down, the valves were "clean as a whistle"
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I found some Sea Foam but need a suggestion on how to get it into the system. It says to use the PCV or something to draw it directly into the intakes but I'm not sure what to do on an 88 3.2...any suggestions?
TIA
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Berrymens Chemtool B-12. Change oil after a couple tanks.
1975 911 Carrera BLK/BLK |
