Rust experts, is this structural?
Hello,
can you tell me if this is rust is structural or can be cosmetically repaired?
Josep
1968 911L soft window targa
1970 911T coupe
1967 911 Soft Window targa
1969 911S 2.0 targa
1977 911S Sunroof coupe
1979 911 Turbo 3.3
Old 08-02-2004, 01:53 AM
JNadal's Avatar
hit a bump in the road and your suspension will probably go through the car.
Old 08-02-2004, 06:05 AM
My guess is there is going to be a bit more than you can see there. There is really no such thing as cosmetic rust when it has gone all the way thru.
Old 08-02-2004, 06:09 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
Is this yours or a vehicle you are considering?
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 08-02-2004, 06:11 AM
It's not mine yet but I will probably buy it. The seller has told me is not structural but I will ask for a photo of the suspension pan.
Josep
1970 911T coupe
1969 911S 2.0 targa
1979 911 Turbo 3.3
Old 08-02-2004, 06:30 AM
MBruns for President
JeremyD's Avatar
That's about as structural as you can get.
Old 08-02-2004, 06:42 AM
Gon fix it with me hammer
svandamme's Avatar
it'll buff out though
Stijn Vandamme
BIMDIESELBMW116D2019
Old 08-02-2004, 06:47 AM
lateapex911's Avatar
Tip of the iceberg. There is a lot more. Go over that car with a fine tooth comb, and be prepared to play hardball on the purchase price, as it will be very expensive to rectify all the issues. There are lots of areas that aren't that easy to see that ARE important that rust will destroy, like the batt boxes, the fender joining panels, the rocker and sub rocker, the door post and its internal supports, not to mention around the T bars and other susp pick up points.
If this is a car you are buying long distance, you need an independant inspection (PPI), or a phenominal price to make it worth the risk.
Now, having said all that, I could be wrong, and that could be the only spot on the car with issues....but......better safe than sorry. To me it's a big yellow flag, and to others it might be red.
Good luck, move carefully.
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 08-02-2004, 06:48 AM
Alter Ego Racing
ErVikingo's Avatar
Josep,
Been there before. I wouldn't buy unless the price is SUPERB. IMHO, if you have rust in tat area, most certainly the bolt area of the suspension pan is toast also. If I interpret the pic ocrrectly, this is the left battery box area so my suspicion of suspension pan rust is pretty accurate.
You will want to check the usual suspect areas plus the area just forward of the door jamb where the fenders bolt in. I found rust in my last car there only after removing the fenders as it was nicely covered with Klagg and years of dirt (which probably accelerated the oxidation process).
In my experience, look at the battery boxes, suspension pan, jack points, door jambs/longitudinals, lower corners of windshield and rear screen.
Hope this helps, Juan
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion
Old 08-02-2004, 06:58 AM
david.avery's Avatar
Seeing rust pics like this remind me of the 71E, 73T I had that both were converted into "fred flintstone" like operation. Longs gone, front susp pan gone, torsion tube, windshield posts.
I remember getting quarter cuts from oklahoma foreighn weekly
I still get nauseous looking at stuff like that... Thought I love the look of the pre 74 cars, I must go galvanized, or backdate an SC/Carrera!
David Avery
05 Lotus Elise (sold) | 08 BMW 135i
visit FocusedE, my e-business company | visit Spyderclub
Old 08-02-2004, 07:41 AM
dtw dtw is offline
GAFB
Not sure where the 'structural' comments are coming from. The photo you show is of the leading edge of the fender mounting flange, where it joins with the nose. Certainly not structural, and absolutely unrelated to the suspension pan, but definitely something that needs to be repaired. I interpret 'structural' to mean a component or area that contributes to the strength/integrity of the chassis/suspension.
As others have mentioned, if there is rust here, there IS probably more elsewhere. If you are not familiar with all the places to look for rust on an early 911, it is in your best interest to take the car to someone who is, prior to purchase. Where are you located?
Several BMWs
Old 08-02-2004, 07:51 AM
I'm quite familiar with typical rust places but this one was quite new for me.
I have 2 911's and taking a look there don't seem to specially mean rust to be translated to suspension pan but I wanted to hear other opinions.
There's other rust in the car, in the base of the driver's side targa bar and a small hole in the driver's floor panel that was repaired in the past.
The car will be a project car, something that I want to do in my spare time without any hurries or stress.
Josep
1970 911T coupe
1969 911S 2.0 targa
1979 911 Turbo 3.3
Old 08-02-2004, 09:01 AM
dtw dtw is offline
GAFB
Agreed, rot in the fender flanges has nothing to do with front pan. Incidentally, there are repair pieces available for this - Check out www.restoration-design.com, it's #32 I believe in the 911 section.
The rust in the base of the Targa bar section sounds scary - that IS structural to the roll bar and is extremely difficult to repair. It's also one of those "tip of the iceberg" situations.
Several BMWs
Old 08-02-2004, 09:11 AM
Chuck Moreland's Avatar
That is not structural.
That area can be repaired, I've done it. But it is difficult because several peices come together.
As above, that rust is a red flag to inspect verycarefully for more.
Chuck Moreland - elephantracing.com - vonnen.com
Old 08-02-2004, 09:41 AM
JNadal's Avatar
If the car is sitting there or getting towed - no big deal, but it looks like the rust would have gone through the suspension pan - NOT driveable.
It also looks like the area has been repaired before, if so, there might be other issues; if someone (with at least an average IQ) took time to restore that area, but didnt do anything to protect it, Id be wondering what else is wrong with the car. Youll probably need to be prepared to pay more for parts than what you pay for the car.
How much is he asking for it?
Old 08-02-2004, 10:42 AM
techweenie's Avatar
Because the area is rarely rusted, you may be able to pick up a patch panel from a front tub to fix it.
As others have said, the issue is not that spot as much as it is what that spot implies for more critical areas of the car.
This better be a bargain car!
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 08-02-2004, 10:52 AM
Hi,
it's a matching numbers 1970 911E, I will pay $3900. Needs new paint, rust here, few bubles in the base of the targa bar, not rusted though yet, targa top needs recovering ... but seems a good solid base.
In the past other 911s I have owned have had some rust work also, nothing serious. In my experience, rust is important to avoid purchase but only if it's in vital places.
Josep
1970 911T coupe
1969 911S 2.0 targa
1979 911 Turbo 3.3
Old 08-02-2004, 10:57 AM
JeremyD's Avatar
Ok, I must be missing something here - I thought I understood where the picture was taken - Maybe just my lack of knowledge of early cars - But isn't this structural? There is a crack in the metal that would indicate some sort of torsional flexing... No?
Please excuse my ignorance - as usual I learn something everday from this board...
Old 08-02-2004, 11:15 AM
I think the close scale of the picture is confusing some of the posters above. That is not the pan, you can not even see the pan or the battery box.
That is the latch plate for the hood.
Old 08-02-2004, 11:16 AM
dtw dtw is offline
GAFB
I must be on everyone's ignore list or something.
As stated above, there are panels ready to go to replace this area. Sounds like you know your way around a 911. Good luck with this project, if the rust is indeed as confined as you mentioned, it sounds like a worthwhile project. How is the front pan and longitudinals?
Several BMWs
Old 08-02-2004, 12:45 PM
