Front Shock Insert Question
I've convinced myself that I can cope with replacing the front damper strut inserts! I shall be doing the rears this weekend.
But - I know that Bilstein inserts (for Boge strut) do not ship in the UK with the wrench for the gland nut that holds the insert in the strut.
I have contacted Bilstein in the UK and they have a wrench thay can sell me. Problem is I need to confirm what the gland nut (or the wrench) looks like.
Bilstein described it to me as basically a 'C' type wrench with a couple of 'pins' to engage in two cut-outs in the gland nut.
Can anyone confirm, or perhaps even post a pic?
On another point, anyone know if it's possible to replace track rod end gaiters without replacing the track rod end itself? The PO fitted turbo tie rod conversion just over a year ago. I noticed that one of the gaiters is now split.
Many thanks.
"Racing is Life. Anything that happens before, or after, is just waiting"
1988 Carrera 3.2 Sport Coupe - my mistress
2012 BMW F11 touring - the dog bus!
2017 VW T6 Transporter - the holiday bus/workhorse
Old 08-03-2004, 11:58 AM
Senior Member
Jdub's Avatar
You might consider going to you local bicycle shop and purchasing a "C" ring used to remove the lock ring on a bottom bracket. This will engage only one notch of the four-notched lock nut, but it was enough for me. You may need also to resort to a cheater bar in some manner.
The bicycle wrench ought to cost you no more than about $15.00. You might compare that to what Bilstein is charging you (funny they should do that - it is supposed to be free?) and go from there.
John
'78 Targa in Minerva Blue
Old 08-03-2004, 12:36 PM
a pair of large channel-locks does the same thing.
206 637 4071
Old 08-03-2004, 12:56 PM
Thanks guys.
I take it my description sounds like the right tool that Bilstein have? I don't mind paying a few pounds for the right tool, but wasting money is very irritating!
Interestingly, Bilstein told me that the gland nut doesn't need to be torqued to a high figure. Indeed using their tool I doubt that you can easily measure the applied tightening torque.
Old 08-03-2004, 01:44 PM
echrisconnor's Avatar
Mine were almost hand-tight. If none of the above solutions work for you, you might even be able to use your fan pulley wrench if it's the c-type. I used a bottom bracket bicycle wrench which worked great. No need for a specialized tool.
It's also useful to have the same type of spanner/wrench to hold the top washers in place when torquing the strut after reinstallation.
'76 911 Carrera 3.0
Old 08-03-2004, 02:08 PM
Zeke's Avatar
I thought it needed a fairly high torque. You can't see it and you don't want it coming loose. I went with JW's tool. Yes, it leaves marks, but again, you can't see it.
Old 08-03-2004, 02:09 PM
golfnow's Avatar
Pipe wrench, its not pretty but it does the job.
Mike Minister of YEP
1986 targa 3.2 " RED"
1970 Little T (Wife’s car)
Gruppe B # 917
Old 08-03-2004, 02:37 PM
chuckw951's Avatar
Is this the tool you are talking about? It came with a set of front shocks I bought but not yet installed.
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler
Old 08-03-2004, 04:12 PM
golfnow's Avatar
So that’s what it looks like. Just a
little better than a pipe wrench.
Gruppe B # 917
Old 08-03-2004, 07:26 PM
Just wanted to say thanks for the info.
The picture will be really useful in making sure I get the right tool from Bilstein here in the UK.
Planning to do the job in a couple of weeks.
Old 08-06-2004, 01:11 PM
CHILI's Avatar
I too put Bilstein inserts in Boge struts about a year ago. Doing withought the tool was a big PITA. As for the torque, I think I guessed and used 65lbs. What do you guys think? Too much, too little.
I also had to undo my brake hose because it was just a smidgen too short to allow the old Boge insert out from under the fender. Even when I turned the steering wheel. Man, it was so close, but wouldn't make it. I had new "soft" lines from Pelican, so maybe the newer lines are a bit shorter than the stock lines, not sure.
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 08-06-2004, 02:51 PM
golfnow's Avatar
For what it's worth my KONIs said 89 ft.ibs on
BOGE struts
Gruppe B # 917
Old 08-06-2004, 03:22 PM
