How to remove dash vents?
I want to remove the dash vents in the ends of the lower dash panel in my 88 Carrera.
I can remove the screw in the end of the panel, but don't see where I go from there. Can anybody help? Thanks.
"Racing is Life. Anything that happens before, or after, is just waiting" 1988 Carrera 3.2 Sport Coupe - my mistress 2012 BMW F11 touring - the dog bus! 2017 VW T6 Transporter - the holiday bus/workhorse |
Bump.
Anybody?
Gently start to pry them out. there are four flat pieces of spring steel afixed to the plastic vent and besides the one screw they are actutally just wedged in.
Keith Epperly 87 slant nose turbo look carrera cabriolet |
Not as it seems
can that be said for the ones in the center of the dash as well? i have the horizonal deflectors missing on mine. well they are not missing they are floating around in the duct work and when i turn the fresh air fan (old AC fan) it sounds like a windchime. i would like to remove the outer deflectors and remove the small bits that float around.
will the center vent just pull out too by prying at each end?
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
that looks exactly like mine.. thanks for straightening me out 'cause I gotta revisit that vent.. and logic says they should be on the top & bottom.
