How to remove dash vents?
I want to remove the dash vents in the ends of the lower dash panel in my 88 Carrera.
I can remove the screw in the end of the panel, but don't see where I go from there. Can anybody help?
Thanks.
"Racing is Life. Anything that happens before, or after, is just waiting"
1988 Carrera 3.2 Sport Coupe - my mistress
2012 BMW F11 touring - the dog bus!
2017 VW T6 Transporter - the holiday bus/workhorse
Old 08-08-2004, 12:18 PM
Bump.
Anybody?
Old 08-09-2004, 11:31 AM
Gently start to pry them out. there are four flat pieces of spring steel afixed to the plastic vent and besides the one screw they are actutally just wedged in.
Keith Epperly 87 slant nose turbo look carrera cabriolet
Old 08-09-2004, 12:22 PM
More Likeable IRL
juanbenae's Avatar
can that be said for the ones in the center of the dash as well? i have the horizonal deflectors missing on mine. well they are not missing they are floating around in the duct work and when i turn the fresh air fan (old AC fan) it sounds like a windchime. i would like to remove the outer deflectors and remove the small bits that float around.
will the center vent just pull out too by prying at each end?
Old 08-09-2004, 01:36 PM
it's how I removed my AC center vent.. gently with patience.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-09-2004, 02:03 PM
steve911's Avatar
I think the tabs are on the top and bottom, not on the sides, but I'm not 100% sure. I need to do the same repair on my vanes, so I'd be interested to know before I start (gently) prying to try and remove it.
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 08-09-2004, 02:55 PM
it was awhile ago. so almost positive the center vent tabs are on the sides.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-09-2004, 03:15 PM
steve911's Avatar
Found these pictures on the PP classifieds - with tabs on top and bottom. These are from a mid '80s car, so earlier/later ones may not be the same...
RIP Warren
Old 08-09-2004, 03:53 PM
that looks exactly like mine.. thanks for straightening me out 'cause I gotta revisit that vent.. and logic says they should be on the top & bottom.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-09-2004, 04:46 PM
