Oil problem.
When I took of the oil-cap to check the oil, the engine stops.Is there any other way to check the oil quantity?
Old 08-10-2004, 09:46 AM
Per-C,
Most 911's will slow the idle when the oil cap is removed, if yours stalls your idle may be too low or there are other issues with ignition or feul delivery. Tell us a bit more about your car and what the current idle is at and some of the immense talent on this board will jump in to help. (note I may be immense but I am NOT talented and resent any implication thereof)
Richard Lane
1978 911SC
1973 "Clean" RS clone
Old 08-10-2004, 10:42 AM
VincentVega's Avatar
I used to check the oil with one hand on the throttle and the other on the disptick. Not fun, but it works. I *think* I fixed the problem with new intake gaskets, misc seals and vacuum hoses.
Old 08-10-2004, 11:05 AM
Designer King
Paulporsche's Avatar
I think that even if your engine has stopped just prior to taking out the dipstick, you would still get the same reading as if the engine remained running.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-10-2004, 03:35 PM
Bill Verburg's Avatar
You didn't mention the yr or model, but there is supposed to be a restrictor in the oil tank vent of late cars to prevent excess unmetered air from causing the engine to stall when the oil cap is removed.
Do a search the part # has been posted several times.
Bill Verburg
Old 08-10-2004, 03:43 PM
Thanks for the help.Just bought it 2 weeks ago.It is a 85mod 911 3,2 C2.Its my first Porsche.It looks like my oil level sensor is broken.From Norway so excuse my bad english.
Old 08-11-2004, 05:50 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
I hope that I am remembering this correctly, because I might not:
If your motor dies when taking off the oil cap then there is a leak in a vacuum hose. I did not find what I was looking for on a search for Vacuum Leaks, but I did not have much time to search either. If this is the case, tracking down the leaking hose (most likely culprit) should be a fairly simple job that will consume up to a couple of hours and some beer.
Your English is fine. Better than many I talk to in The States every day!!
Oh, and welcome aboard!!! We have many other members from The North!!! Hopefully one is near you!
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 08-11-2004, 07:26 AM
GB83SC's Avatar
Take a pair of vicegrips and place it on the hose ( basicaly pinching the hose closed) that runs from the oil filler neck to the back of the engine. There should be a (tiny funnel) restrictor in one of the hoses, if this is missing there is the issue.
George
My Owners Gallery Page
1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running.
1995 BMW 525I
2001 Highlander- kid mover
Old 08-11-2004, 07:37 AM
GB83SC's Avatar
Here is the parts numbers:
beware when changing breather pipes!
George
1995 BMW 525I
Old 08-11-2004, 07:50 AM
