wright77's Avatar
Question Power window problem
I started to raise the passenger window last week, and the switch on the door broke. ( passenger side switch). Than I couldnt raise or lower either window.
No problem, I ordered a new switch, hooked it up, still neither window works. I checked the 25 amp fuse, it was blown.
Tried 3 times to put a new fuse in, as soon as I turned on the ignition, it blows. Any ideas? Is there a separate power window relay that might be bad?
I traced the black wire in the fuse block for the power windows, and it goes to a round relay. A another red wire gows to this relay, and it is for the blower motor , which works fine.
Thanks!
Old 08-10-2004, 06:21 PM
Re: Power window problem
Originally posted by wright77
Any ideas?
" Any ideas?"
------ yep. The sw solid red is somehow contacting the brown ground.. if your lucky?
"power window relay that might be bad?"
------- I doubt it 'cause this all started when you changed sw's.
The black wire goes to the window relay. Then there should be a red/white & red/black connected to this relay. There may be 2 red/white wires comming together at the relay instead of one red/white.
why not list your model year and any mods in the "signature" to aid future reference.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-10-2004, 07:21 PM
wright77's Avatar
So with the broken passenger switch, it affected the operation of the drivers side? I will check my wiring!
Thanks Ronin!
Old 08-10-2004, 07:42 PM
I may have gotten the sw colors crossed, but I would check all 3 sw's to make sure no hot is grounding.. A hot wire may be grounding into the door inner sheet metal when the sw is mounted.
All 3 sw's use one fuse.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-10-2004, 07:55 PM
wright77's Avatar
Wink
I checked and corrected my wiring, put a new fuse in, and they work fine! Thanks!!!
1978 911 SC
Old 08-11-2004, 07:10 AM
