Used underbelly condensor...
I have a chance to pick up a used, including all hoses and fittings, underbelly condensor from a guy who just upgraded to a Griffiths system.
Plus, the folks who installed his Griffiths will install this for me.
Tempting...indeed. Plus I see folks seem to like the underbelly condensor.
What would a reasonable price, assuming the system is in good condition, price be for the condensor..??
Phattey....
'87 911
'95 4Runner
'05 Screamin Eagle ElectraGlide
Old 08-11-2004, 06:32 AM
If you plumb the belly condener between the Griffiths left rear condenser and the drier, rearrange the condenser's fittings.
Move the inlet (on the right side) to the left side, pointing to the rear. Turn the outlet (on the left front) around so it faces forward.
That makes it a straight-thru plumbing job.
Old 08-11-2004, 03:22 PM
rfuerst911sc's Avatar
I recently purchased a used under belly condensor and the barrier hoses that went with it for $300.00 including shipping off E-Bay,I am making it my winter project.
Old 08-11-2004, 06:04 PM
75'930cab's Avatar
What is the size of the condensor?
67 Triumph TR4a irs
72 DeTomaso Pantera
75 911 3.3 Turbo Cab*SOLD 5-11-04
73 911T Went Up in a Blaze Glory, 76 Early Ford Bronco
Old 08-11-2004, 07:22 PM
WydRyd's Avatar
8' x 4' I think. I have one sitting at home. Will install it when nearing summer
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 08-11-2004, 09:28 PM
Administrator
Jack Olsen's Avatar
Just make sure it's the stainless steel model that Performance Aire sells. An ordinary condenser is going to get destroyed, down there.
Old 08-11-2004, 11:19 PM
