BoxsterGT's Avatar
Porsche Crest Alternate fuel pump question
I bought an alternate fuel pump online and need to find the correct electrical connectors to fit this pump.
Is this some new Chinese or Japanese standard electrical connector that the local NAPA or Flaps does not know about? Ready to test this pump but want the proper connectors to finish the job.
Len
Old 02-20-2013, 09:32 AM
scarceller's Avatar
That looks like a would take a simple female round spade to plug into the round male?
Not sure what the threads are for on the plastic?
You sure that the red and blue plastic don't simply screw out?
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 02-20-2013, 10:49 AM
BoxsterGT's Avatar
Porsche Crest
They appear to be glued or bonded in place. It looks like the connector screws down over the male terminal to make contact.
Len
Old 02-20-2013, 01:19 PM
SchnellSchweitz's Avatar
What is the pump manufacturer?
More discussion: http://forums.thecarlounge.com/showthread.php?5724051-Fuel-Pump-wiring-connector...New-Pump-strange
'82 SC 3.0L Targa, Chiffon/Brown
“It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche
Old 02-20-2013, 01:36 PM
So it appears these connectors are for older Audis. Here's what the harness looks like with the female connectors. If you could find an Audi fuel pump harness for late 80s and early 90s models you may be able to use them.
http://carphotos.cardomain.com/ride_images/1/3328/4941/8319970004_large.jpg
Otherwise, you may need to remove them and just use the standard threads and a circle clip connector and a rubber boot.
I actually like these Audi connectors and wish there was a source for them. I'd use them! :-)
Old 02-20-2013, 07:34 PM
Senior Advisor
James Brown's Avatar
they do look slick
08 Cayenne Turbo
Old 02-20-2013, 11:29 PM
BoxsterGT's Avatar
Porsche Crest
This Pelican Board ROCKS!!! Thank you Gentlemen & Ladies.
The pump is from mpgautoparts dot com. I think it was $60 and appears to have the right flow for most efi vehicles. Cheap enough to give it a try.
Now to find these connectors at Audi.
Len
Old 02-20-2013, 11:46 PM
Just an FYI:
This may be your source for the nuts????
I would call to confirm before ordering. Let us know what you find out.
Part numbers are: 811971903 and 811971903A I think???
Knurled nut fuel pump. KNURELD NUT. Audi # 811971903A
Sealing bushing. SEALING BUSH FOR. Audi # 811971909
OR
http://www.ecstuning.com/Search/811971903/?gclid=CMaU-Zznx7UCFWhyQgodp28A1w
Old 02-21-2013, 08:02 AM
scarceller's Avatar
The Audi style connector will not be as reliable and tight as the stock threaded stud. I'm sure you'll be OK with the Audi connector but I think the stock threaded stud is simply better.
Sal
1964 356SC (SOLD)
Old 02-21-2013, 08:10 AM
Walt Fricke's Avatar
A clever aspect of Porsche's wiring system on the fuel pump is the diameter difference between the positive and negative posts. Because the ring connectors on the wires are also different sizes, you can't really get polarity reversed. These look like you could, despite the nice color coding, get things hooked up backward. A small matter, of course - it is certainly well marked.
Old 02-21-2013, 10:52 AM
