The Chef
Guest
Posts: n/a
Originally posted by Chuck Moreland
Aren't you glad you decided to paint the trunk body color?
It's looking sharp.
German autofest is looking very doable.
Yes I am! I can actually see the wiring harness and all the other goodies in the trunk. I am going to put the new front suspension in this weekend. Then i will finsh the wiring, plug in the juice and see how many fuses i pop and go from there. I did label everything before i took it apart but some of the labels came off.
Man i hate putting all the components back knowing that im just adding unwanted wieght. Do we actually need wipers in southern cali! Anyway, here is a shot of the nice and clean engine bay.
Old 08-13-2004, 11:21 AM
The Chef
Guest
Posts: n/a
P.S.
Thanks for all the great comment guys. Its been a long year and its nice to finally see it come together.
Old 08-13-2004, 11:24 AM
Randy Webb's Avatar
I think you'll find that paint doesn't stick to the pot metal that recieves the rubber seal. No biggie.
Also, you _could_ put in a 944 wiper/motor assy. for driver only - Jim Calzia did that in his light wt. car.
Old 08-13-2004, 01:24 PM
The Chef
Guest
Posts: n/a
Randy,
Anything is better than what I had. Its a cheap paint job but at least its all one color. Good paint was not in my budget. If was, I would have brought it to Kevin P at automotive restorations. Anyway its a track car. It just has to look good from 30 feet away and traveling...
Old 08-13-2004, 02:00 PM
The Chef
Guest
Posts: n/a
OK
I decided to tackle the front suspension tonite. I couldnt stand to see that 914 front suspension on the car anymore. Thank you Dave B from TREMOTORSPORT.COM for the use of it while my car was gettig painted. Also thank You Kevin p for the use of the 914 wheels.
Luckily Tyson Schmidt is in NY picking up his new 69 or he would not let me work on my car. Its more his baby than mine. With that said I was able to figure out the best way to do it. I think!
Step1
Assemble rack to cross member. Properly torque and use blue locktight. I greased the tortion bars and put them in the control arms. I had to tap in the cotrol arm to the cross member because i had the arms powdercoated. More for protection than looks.
Step2
I didnt want to scratch anything so i assembled everything on cardboard and slid it under the car. I proped up one side and started bolting up the other side leaving all bolt loose til everything was boltedup. Then I tightened everything up.
step3
install struts.
Well thats about as far as I got tonite.
Old 08-13-2004, 11:27 PM
adomakin's Avatar
loving your work joseph!
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 08-14-2004, 11:56 AM
Sports Purpose 911 Driver
mjshira's Avatar
Joseph
Tyson and I are here in NYC recovering from hangovers, last night we had a bunch of guys out talking Porsche until late in the night. The ride looks good! I look forward to seeing your car in person!
James
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 08-14-2004, 06:17 PM
The Chef
Guest
Posts: n/a
Thanks James. I talked to Tyson on Friday. Sounded like he was enjoying the NY weather. I would have went if I had the time. NY is my home town and thats my neck of the woods. I was hanging out in Hells Kitchen when it was Hells Kitchen. You had to fight your way into a bar and fight your way out. Now that all the Yuppies moved in they renamed it "Clinton".
Old 08-15-2004, 11:01 AM
Randy Webb's Avatar
"Hells Kitchen when it was Hells Kitchen. fight ... bar ..."
So it's actually O'herreros ??
-- just joking -- ti was notorious Irish slum in the 1800's
Old 08-15-2004, 01:43 PM
The Chef
Guest
Posts: n/a
Thats how I remember Mr. O'webb. It was actually affordable by NY stadards to live there about 10 years ago. A 2 bedroom went for about 1200.00 a month. 1500sq ft . Those were the days! Prostitutes walking the streets, drug dealers on the corner, and not a cop in site! I dont miss one bit of it. You guys can keep it all!
I marked every corner Years ago! Squirt, squirt
Old 08-15-2004, 04:16 PM
The Chef
Guest
Posts: n/a
Its sunday and I just finished the front suspension. Cleaned evertything that neede cleaning and painted what was needed.I had to make a bracket for the horns. The stock ones must have wieght 5 pounds. I cleaned up the lights and housings and assembled them. I also cleaned up some of the overspray in the wheel weels where it was noticeable
The tie rod ends took me some time. I wanted to measure the exact center of the steering, then insert the tie rods into the spindles. I did an alaignment by eye for now untill i can get it to the shop. looks pretty good. I also centered the steering wheel.
So I go and put the front wheels on and after give the wheels a spin. MMM, very tight and making sharp grinding noises. Then i dawned on me that my spindle were raised and the ball joint hits the bottom of the wheel. No big deal because it not going anywhere. 17 wheels are on the way.
I finished off by putting on the front grill pieces, porsche emblem, and a few little things. I have to say that I am liking the way that it is starting to look. Anyway that was the prgress for the day.
Tomorrow is the alaignment of the front bumper and the wiring in the rear of the car.
Here is a couple of pics. Enjoy!
Old 08-15-2004, 08:34 PM
Randy Webb's Avatar
YOu said the paint was not that great, but it looks fabulous in those photos. Quite a project.
How much will it weigh?
Old 08-15-2004, 09:12 PM
I think its look great!! Love the color also
Chris
Old 08-15-2004, 10:42 PM
I think it looks great!! Love the color also
Chris
Old 08-15-2004, 10:43 PM
The Chef
Guest
Posts: n/a
Thank you Mr. O'webb.
Im not sure yet.. When its done ill take it to TRE and weight it. Somewhere around 2100pds I guess.
Old 08-16-2004, 12:16 AM
}{arlequin's Avatar
it's looking better and better!
dave
1973,5
Old 08-16-2004, 06:27 AM
Send a message via Yahoo to E30Mracer
Looking at these pictures here is the best motivation for me to go look for a better job I must move to CA and build me a nice early 911 and actually get to drive it - unlike in Philly where this summer had been nothing but rain, humid and ... more rain. And then Fall will come and...
Oh well, GREAT car and GREAT color!!! My fav for sure :P
Old 08-16-2004, 07:35 AM
The Chef
Guest
Posts: n/a
It worked for me!Ladies arent too bad either. Best Ive seen anywhwere actually. Also where else do you see million dollar cars parked at meters and being valeted.
Just DUU it. DUU it.
Old 08-16-2004, 11:39 AM
SWEET ! Keep it going Joe- we have your spot at GAF waiting
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 08-16-2004, 11:44 AM
Team California
speeder's Avatar
Thumbs up
Wow, looks great! You are doing a fantastic job of cleaning things up as you reassemble. That is the way that I like to do it as well, then drive it and enjoy it w/ regular old washings. It'll stay nice for a long time. Nice work!
Denis
Old 08-16-2004, 11:54 AM
