Licensed User
Shuie's Avatar
Big red warning light
http://dtmotorsports.com/products/bigredlight/
Has anyone ever modified one of these to work as a warning for more than just oil pressure? Like a combo cylinder head temp, oil temp, oil level, and oil pressure warning light?
Old 08-13-2004, 09:59 AM
Grady Clay's Avatar
Sherman,
The three critical issues are:
Oil pressure – you have to get your foot off the gas and on the clutch ASAP. Don’t ever let the clutch back out to see if it will restart.
Fan belt – you need to get out of the gas and coast to a stop.
Fuel pressure – you need to stop for fuel soon.
Most like to have warning lights positioned close to their normal vision and in proximity to the same function gauge.
I have a 35 PSI oil pressure switch (917 P/N) that comes on below about 4000 RPM. Under extreme revs, cornering, and braking I can get it to light briefly.
I also have a fuel pressure switch that starts to occasionally light in corners when the fuel gets low.
The goal is to give some advance warning.
Has anyone had one of the instrument shops install some really bright LED warning lights in the stock instruments and maintain stock appearing? I like my analogue quartz clock.
BTW, what is with that sand blasted pedal assembly?
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 08-13-2004, 10:30 AM
Licensed User
Shuie's Avatar
Thanks Grady.
I just did a search and found some good stuff from Warren.
Electric Gurus: Monster oil light wiring
Old 08-13-2004, 10:50 AM
Love the RS on the glove box door. Can I get that part somewere? Randy
Old 08-13-2004, 10:51 AM
