front weltmeister sway bar clunk
I have a 22mm weltmeister front sway bar in my 73.5 911T and it is extremely noisy. Any suggestions?? Thanks, jim
It most likely is shifting side to side, hitting the body. Do you notice it right after a quick turn? Try to remove the play with spacers or by moving the arms inward.
What kind of noise?
Plasticbushing are known to make noises, try to lubricated them. They could also be worn.
You might not be happier owning a Porsche, but it certainly feels so driving one |
It rattles in the bushings even when the car is traveling straight down the road and slides side to side when I grab hold of it. I will try to make some adjustments by moving the arms inward and adding spacers. Do they sell a softer rubber bushing for use with the weltmeister bar?
