jim brown's Avatar
front weltmeister sway bar clunk
I have a 22mm weltmeister front sway bar in my 73.5 911T and it is extremely noisy. Any suggestions?? Thanks, jim
Old 08-15-2004, 10:58 PM
It most likely is shifting side to side, hitting the body. Do you notice it right after a quick turn? Try to remove the play with spacers or by moving the arms inward.
Old 08-16-2004, 04:17 AM
palle7688's Avatar
What kind of noise?
Plasticbushing are known to make noises, try to lubricated them.
They could also be worn.
You might not be happier owning a Porsche, but it certainly feels so driving one
Old 08-16-2004, 04:48 AM
jim brown's Avatar
It rattles in the bushings even when the car is traveling straight down the road and slides side to side when I grab hold of it. I will try to make some adjustments by moving the arms inward and adding spacers. Do they sell a softer rubber bushing for use with the weltmeister bar?
Old 08-16-2004, 06:53 AM
