Window regulator
Hi, just wondering if the window regulator for manual are the same for power windows. Will a manual system bolt right in where a power once once was. I had power and am coverting over to manual. I noticed that the door has a hole for the manual window handle. Will the other bolts line up the same? Anything I should be aware of? I probably should have asked before I gutted the windows, regulators and motors from the doors.
Thanks, David |
David, years of car and parts?
Warren & Ron, may you rest in Peace. |
Sorry, my bad. 77 911 3.0 Carrera. Same body as SC. I think someone here had said all the doors are the same from the early seventies up through the late 80's.
Thanks, David |
nice doggie
Should bolt right in. You will need to redo your door panels.
Jerry 78 SC hotrod 02 Mini Cooper S |
Thread Tools | |
Rate This Thread | |
