North Coast Cab's Avatar
Which Way ICV?
Took the ICV off to clean and forgot which way the arrow should point.
John
1985.5 944 GTS
Old 08-16-2004, 05:52 PM
The arrow points in the direction of the airflow, which as I recall should be pointing downward toward the engine.
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 08-16-2004, 06:28 PM
kqw kqw is offline
Arrow Down......
The Fox
Carrera
Old 08-16-2004, 06:33 PM
Make Bruins Great Again
Por_sha911's Avatar
Quick Question: after cleaning does it rattle when you shake it (like a can of spray paint). Mine clicks but doesn't rattle (need further cleaning?)
Joe
Old 08-16-2004, 09:44 PM
Joe,
If I shake it really hard to will rattle a little. Not sure if this is enough. I'm going to clean or soak thoroughly and try again. It;s worth a little effort to save the $159 for a new one.
John
1985.5 944 GTS
Old 08-17-2004, 07:19 AM
GFCC
Jeff's Avatar
You can carefully pry the tabs on the side up and take it apart for further inspection / cleaning. Make sure you make orientation marks before disassemble. It will change the resistance at the plug (and not work correctly) if not assembled in the same orientation.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 08-17-2004, 07:40 AM
Connect your ICV to a 12V
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 08-17-2004, 07:55 AM
As I was saying, connect your ICV to a 12V source and you should get a brief clicking sound as the valve opens up for just a split second. Use carb cleaner liberally (let it soak for awhile), then some compressed air to clean out the mess.
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 08-17-2004, 07:57 AM
It looks like there is a screw hole on the end, though there is no head on it. Is this for disassembly? I've been liberally spraying with carb cleaner and shaking like crazy. If it doesn't work I guess I have nothing to lose taking it apart.
John
1985.5 944 GTS
Old 08-17-2004, 08:12 AM
