LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average.
I tested my stock 87 Carrera before and after installing a nice pre-muffler. My results were 180 RWHP with the cat and 187 with the pre-muffler. I did not do a full power curve, just max HP, but wanted to at least chime in as one other person who has tested this. I also tested with the OEM muffler and with a performance muffler and actually lost a few HP at the top with the performance muffler.
Bill
Old 08-18-2004, 08:22 AM
911-32's Avatar
Originally posted by dickster
wavey,
appreciated, but we're talking dyno numbers here - thats what steve referred to.
thats a great increase on that dyno sheet - imho more of that is attributable to the pre-muff than steve gives credit. i'm guessing around 10hp came from the cat swap.
diont get me wrong, i'm a fan of steve's and have thought about buying one of his chips.
howabout steve donates a chip and i get it dynoed on my car with my current setup (already dynoed) and i'll take it back to the same place?!!
There are a bunch of 3.2 owners in the UK who plan to do just that with the SW chips already purchased - its just a case of finding the time and organising the day. If you send me a PM I can give you more info.
Richard
Old 08-18-2004, 08:32 AM
Steve W's Avatar
Originally posted by Crachian
Finally some good hard data. THANKS. (by the way, what ever happened to those guys in Virginia who were planning an A-B dyno comparo)
As someone who runs the stock chip and is considering buying one from Steve, I want to know:
Is leaning out the A/F at the higher RPMs dangerous?
Why did the factory do it that way?
The factory intentionally programs the air fuel ratios extra rich above 4500 rpm to prevent catalytic core meltdown under sustained high speed full thottle operation such as on the autobahn. The richer mixture creates a cooler exhaust flow which keep the cat cells cool, but this does nothing for power, and is not really a problem in the U.S. with our lower speed operation. Lean is not good either, such as 13.8:1 or leaner, but we are nowhere near that.
Old 08-18-2004, 08:41 AM
nostatic's Avatar
well, I hate to pee in cornflakes, but this is not a "controlled" experiment. You cannot change two variables. You cannot make a single run and declare much of anything. You need (at least) 3 points to make a straight line.
Interesting data points, but I'd be pretty hesitant to drawing a significant conclusion other than "it appears as though the second run has more hp/torque."
Old 08-18-2004, 08:45 AM
Wow, what remarkable restraint. No "Our SC's don't need no stinkin chips" comment...
Warren & Ron, may you rest in Peace.
Old 08-18-2004, 08:53 AM
banjomike's Avatar
Question
What confuses me is that Steve Wong makes these chips, and then relies on customers to get dyno results? If you are designing a chip for a car, and you are going to sell that chip, don't you put the chip in an example of that car and run it in on a dyno as a part of designing the thing in the first place!?!?! If Steve isn't designing these chips with the assistance of dyno testing, then what is he using? Divine Revelation? At the very least it seems to me that someone selling a go-fast part (especially one as easy to swap as a chip) would test the product on a dyno at their own cost for marketing purposes. Come on, three runs on any old carrera with a stock chip, swap'em out, and three more runs with the new chip. @ $150/hour for unlimited runs, how long could this take!?
I'm just baffled that this is even an issue, it seems like the dyno would have been used either for R&D or marketing.
Mike
Searching for a new ride
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
http://www.pelicanparts.com/gallery/BanjoMike
Old 08-18-2004, 10:52 AM
Wavey's Avatar
Uh, not to pee in the cornflakes, but I believe 2 points make a straight line.
(Homer Simpson voice) Mmmmmmm... pee in the cornflakes....
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 08-18-2004, 10:55 AM
There's stil no denying that when all two ( or three) things are done...as *most* owners will do...then the combined effect of those three changes produce the HP improvements shown on the dyno runs. Pretty good overall improvement for those simple three things....taken together.
I still think it's only an academic and thought-provoking issue taken in this context......
--Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 08-18-2004, 11:36 AM
I'm only a lurker in this chip dept.. so my remarks are only afaik. I'm replying 'cause nobody else has.
The A/F ratio constructs a flame that transfers energy to your piston. The larger the flame the more energy being transmited. Any max flame can be reduced by limiting the air or increasing the fuel. Auto engines operate rich of the desired max flame. There are many instances where a leaner mix will increase this flame from the previously constructed rich A/F, thus more HP. Another issue becomes the deviation between the max flame and the minimum flame among all 6 cyl. This may increase or decrease when adjusting theA/F mix in either direction.
The envelope is the CHT. A bigger flame is doable if the CHT remains within the desired envelope.
whatever. blast away
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-18-2004, 12:15 PM
nostatic's Avatar
If you want a straight line with any hint of statistical information, you need at least 3 points.
Then again, in grad school I watched one of my colleagues draw a parabola using a single data point. And that point wasn't even the vertex.
And I believe that Homer prefers donuts to cornflakes
Old 08-18-2004, 12:22 PM
Lorenfb's Avatar
"What confuses me is that Steve Wong makes these chips, and then relies on customers to get dyno results? If you are designing a chip for a car, and you are going to sell that chip, don't you put the chip in an example of that car and run it in on a dyno as a part of designing the thing in the first place!?!?! If Steve isn't designing these chips with the assistance of dyno testing, then what is he using? Divine Revelation? At the very least it seems to me that someone selling a go-fast part (especially one as easy to swap as a chip) would test the product on a dyno at their own cost for marketing purposes. Come on, three runs on any old carrera with a stock chip, swap'em out, and three more runs with the new chip. @ $150/hour for unlimited runs, how long could this take!?
I'm just baffled that this is even an issue, it seems like the dyno would have been used either for R&D or marketing." - banjomike
Very well put! - a bit mickey mouse product development -
"well, I hate to pee in cornflakes, but this is not a "controlled" experiment. You cannot change two variables. You cannot make a single run and declare much of anything. You need (at least) 3 points to make a straight line." - nostatic
Another very valid & right-on post. I guess few have taken a data analysis or
statiistics class even in H.S.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 08-18-2004, 01:11 PM
not for nothing
I think it's disrespectful for any member to blast another for posting his insights. You don't have to buy into it, But what he sees thru his eyes are important imo.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-18-2004, 01:32 PM
Wavey's Avatar
[QUOTE]Originally posted by nostatic
[B]Then again, in grad school I watched one of my colleagues draw a parabola using a single data point. And that point wasn't even the vertex. [QUOTE]
You're making my brain hurt - how did he do that?
Old 08-18-2004, 02:46 PM
i agree with roninLB. the steve vs loren thing is getting a bit old. we're all entitled to our own opinion. both guys are way better at electronics than i am, and i appreciate hearing both their thoughts. i'm glad there's no one constantly countering me whenever i post. knock it off guys!
206 637 4071
Old 08-18-2004, 04:22 PM
greglepore's Avatar
Well, regardless, what interests me is that the combo gives about 15 hp, which is consistent with what folks have been saying all along. I don't see much benefit in either as a stand alone, really. The motor is an air pump, after all.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 08-18-2004, 04:38 PM
nostatic's Avatar
well, he only got one decent data point out of the experiment, and he was trying to prove that his sytem exhibited "inverted region" electron transfer behavior. So he plotted the point, then drew a curve that "fit" the behavior he expected and went through the data point.
As my o-chem prof once wrote on an early lab report I turned in: "This is science, not science fiction."
Old 08-18-2004, 04:39 PM
Steve's a great guy who loves Porsches. I'd hate to say it, but selling chips isn't his main employment. For the prices he charges and the amount of custom work he does to tune cars, the price of his chips isn't going to make him rich. Having others report back dyno results isn't a problem for me. I think Autothority has there own dyno that they test on. I don't see too many users raving about their chips, at least not on this board.
Old 08-18-2004, 06:12 PM
MBruns for President
JeremyD's Avatar
You know, when all this first started I thought Steve Wong and Loren were the same person. Steve would post something, loren would refute it, then 30 satisfied Steve Wong customers would chime in and blast Loren. I thought it was the most unique marketing game on the planet...
Then I realized that all the happy customers were unique to each post.
Old 08-18-2004, 06:22 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
I'll second that, but I can say I am trying to help him make chips his primary source of income, right Steve?
Personally, I would rather see independent dyno tests from a variety of sources than dyno tests done at a manufacturer's facility. I am firmly entrenched in this industry, I have seen plenty of products over the years make 5 horsepower in the ads and lose 5 horsepower on any dyno other than the manufacturer's own.
BTW Steve, I look forward to seeing you in a few weeks. The motor comes out Labor Day weekend and than the fun starts! You can fine tune my 3.5L twin-plug anytime on the road and dyno.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 08-18-2004, 06:34 PM
Lorenfb's Avatar
I guess many dislike the constructive comments of Dickster, Nostatic, & Banjomike,
and as such ignore them and only focus on posts that support their views.
Remember, this is a forum where all views, either positive or negative, contribute
to enhanced knowledge for all.
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 08-18-2004, 07:27 PM
