Can you change the oil filter on a 3.2 without draining the oil tank? Or will you dump a lot of oil if you take the filter off without draining the tank? The reason why I am asking, I had to change the oil, and did not have a Mahle filter available and had to use a brand X filter, now that I am back home, I want to put the mahle filter on.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
RETIRED
Do it cold and have a towel ready.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Friend of Warren
If the filter you put on does not have an anti-drainback valve you will lose about 1/2 of an oil filter's worth of oil. Less is you are fast. With the Mahle filter I never lose more than about a teaspoon full of oil. Either way, draining the oil has no effect on how much oil you lose when changing the filter.
Kurt V No more Porsches, but a revolving number of motorcycles. |
I've done this and as stated you 'll lose a little oil. jam newspaper or paper towels underneath to catch the spillage. Tip the threaded end up as quickly as possible.
There are no dumb questions. There aren't are there?
'80 SC |
Thanks guys, I have always drained the tank first, so I didn't know how much would come out just taking the filter loose.
