Detached Member
Hugh R's Avatar
I'm not sure what's correct, but if your trying to get rusted or rounded off bolts/nuts off, buy the Sears "Bolt out" sockets as advertised by Bob Veila on TV, they are sockets with internal biting teeth and they really work well to take off round nuts and bolts. Any Sears carries them
Hugh
Old 10-17-2004, 04:39 PM
Does this look bad???
I getting ready to replace the aging exhaust system on my '77 911. So I crawl under there today to take some measurements in order to buy the SSIs (thin or thick), gaskets, spray PB on the rusted bolts, etc. I then discovered that not one but two of the exhaust bolts are...bolts going into flange. What do I need to prepare myself for when removing these bolts and shouldn't there be studs with nuts like the others?
Thanks,
Dean
Old 10-17-2004, 04:40 PM
billwagnon's Avatar
yes, Hugh is THAT good.
Old 10-17-2004, 05:20 PM
How did Hugh's reply end up the first post in this thread ???
Or is it just me?
Old 10-17-2004, 05:49 PM
Stanley's Avatar
Or is it just me?
its the same for me too, I was trying to figure what the thread title had to do w/ Bob Villa sockets.
Also Sears has a coupon out right now for $10 off any tool purschase over $20. Coupon: http://f.chtah.com/i/27/217789800/coupon.pdf
'78 SC
Old 10-17-2004, 05:59 PM
Hey Hugh, can you do that with lotto numbers ?
Old 10-17-2004, 06:05 PM
LakeCleElum's Avatar
Hugh is Pyschic, his reply arrived one minute before the post!!!!!!
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 10-17-2004, 06:22 PM
