rob justice's Avatar
Restarting a 3 year laid up engine
The on going restoration is almost at the engine firing up stage.
The enging has not been started for 3 years but before being laid up I poured some oil down the plug holes and have turned the engine over by turning the fan pulley.
Prior to the first fire up - is there any special requirements for these engines or is it just a case of turn the key and see what happens?
Old 08-25-2004, 02:13 AM
dickster's Avatar
rob,
personally, i would pull the plugs, squirt some oil in each cyl. turn over by hand.
then i would turn off ign/fuel supply and spin the motor over on the starter to get some oil pressure.
then i would go for it.
good luck.
Rich
'86 coupe
"there you are"
Old 08-25-2004, 03:20 AM
Thats pretty close to what I was thinking - whats the best way to disconnect the fuel supply? Fuse?
Old 08-25-2004, 03:34 AM
Slumlord
Porsche_monkey's Avatar
I unplug the fuel pump connector in the engine bay.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 08-25-2004, 05:03 AM
Old gas? If there is still gas in the tank from 3 yrs ago, you may want to drain the tank, at the tank, and pour some fresh gas in, rock the car (or tank of you have it out) for a little while, then drain that gas out. Check your gas lines and filters for build up. Remember, when you drain the gas, that you will have to turn the fuel pump on for about 20 seconds (more if it is an MFI) to get the system filled again BEFORE trying to start it.
Good luck,
Terry Hastings
Terry Hastings
Baltimore, MD
1972 911T
LTHSURVEY@AOL.com
Old 08-25-2004, 05:16 AM
Terry - the tank is empty, repainted etc and all the fuel lines have been replaced apart from the one on the engine itself.
PBH - where's the fuel pump connector in the engine bay? The car is a 3.2 Carrera with Motronic Injection.
Old 08-25-2004, 05:25 AM
Slumlord
If you can't see a connector pull the fuel pump relay. Someone else can help here witht he color, are they red? I cant remember.
84 Cab - sold!
Old 08-25-2004, 05:47 AM
Wouldn't it be the DME Relay under the drivers seat (at least in US)? Wouldn't that also take care of the spark issue too? I have no idea if the starter will/will not turn over w/o relay because I've never tried it. I suspect the starter will turn over just fine but no fire, which is just what you want.
Bill W.
Bill W.
'97 Arena Red / Gray 993 Cab
'93 968 Coupe 6 Spd
'88 911 Cab Red/Blk (sold)
Old 08-25-2004, 08:01 AM
Why would you ever want to sell your 911?
69 911 2.3Ez
85 928S
Old 08-25-2004, 08:29 AM
The DME relay is under the passengers seat - unplugging it seems the way to go.
My plan is to have the engine running within the next 4 weeks and the car road worthy by middle of November all going well!!!!
Old 08-25-2004, 08:48 AM
