Questions on SC brakes
This weekend I installed new brake pads on my 82SC Coupe.
Question?? The retaining pins on the rear breaks have small holes for insert clips to keep the pins from coming out. The front pins are a bit smaller and do not have these holes. It seems to me that the front pins should have these holes and retaining clipes as well, given that most of the breaking is with the front brakes. Did someone simply install the wrong pins in the front?
Also, when attempting to bleed the REAR breakes, I couldn't get a wrench to fit the bleed valve well. The front was no problem...9mm.
What size is the bleed valve for the rear brakes?
Guy Chiattello
82 SC Black coupe
Old 08-29-2004, 01:50 PM
Somatic Negative Optimist
Gunter's Avatar
Rear is 7mm, Bentley 470-5. I am not sure if Porsche used only ATE brakes or if they sometimes used GIRLING. Anyone? If your front didn't have clips, o.k. Make sure that the new pads move freely in the groves with a thin coat of anti-seize paste to sliding edges. Bentley page 460-6.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 08-29-2004, 02:51 PM
Bill Verburg's Avatar
That's correct this is what they should look like
A on the left M on the right
Bill Verburg
Old 08-29-2004, 03:26 PM
Oh, ATE are the only brakes that came stock on 911s(not 930, 964, 993 etc.)
Bill Verburg
Old 08-29-2004, 03:51 PM
Bill, I knew you would respond.
Thanks fellows for the help.
I don't know why it didn't occur to me to look at Bently??
guy
Old 08-29-2004, 05:16 PM
