Assuming the car's torsion bars are sitting on jackstands at their highest setting... if the air cleaner and carburators were removed prior to dropping the engine (70 911T) then would there be enough room?
-Dennis
Old 08-30-2004, 06:23 AM
Hilbilly Deluxe
emcon5's Avatar
-Dennis
That really depends on the jackstands. I don't think you would need to remove the carbs, unless your jackstands are really short.
You really want the bigger jackstands, I think mine are 6 ton. Not only because they go higher, but the larger base makes them more stable.
Tom
82 911SC Coupe
GTI Cup #43
Old 08-30-2004, 06:35 AM
Thanks Tom.
Old 08-30-2004, 06:59 AM
youfamissim's Avatar
12 Ton jack stands
Most 12 ton stands extend to 28" in height.
This will suffice to remove the engine
Old 05-19-2011, 08:59 AM
MBruns for President
JeremyD's Avatar
and if they don't - take a 8' x 12" board and cut it into 8 pieces = glue them together and use them to put your jack stands on...
Old 05-19-2011, 12:19 PM
