Will program for food
ghnat's Avatar
What type of cleaner/solvent do I need?
Removed my pedal cluster and began cleaning it. What I first thought was rust seems to be "highly" compressed dirt.
I have been using (the past two nights) sand paper, wire brush, brake cleaner, carb cleaner and finally a wood chisel. Not all at the same time, I do only have two hands... The chisel works prety well, but I have to use a lot of force and it is tough to use in many places.
Is there any cleaner or solvent that will loosen this stuff up?
Thanks in advance.
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 09-02-2004, 10:04 PM
Registered abUser
TerryH's Avatar
How about one of those high pressure self-serve car washes. If you have to chisel, I'm not sure high pressure water would work unless it could soak overnight perhaps.
'81 911SC Coupe SOLD
Old 09-02-2004, 10:25 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
Soak it in acetone, spray gun cleaner, gasoline works well. Know anyone that has an ultrasonic heated water cleaner? Media blaster? Acid dip, castrol super clean, 3M grease cleaner in aerosol can. Spray gun cleaner is pretty darn strong, I let some sit in a fiberglass bowl I made and it dissolved the resin and pretty much turned the bowl into mush. Scrub, soak, scrub, soak, over and over and over. Who knows, hopefully one of these might work.
74 911s neverending story. two feet and a jetta for now.
Old 09-03-2004, 12:31 AM
jluetjen's Avatar
Lately I've started to use Oderless Denatured Minerial Spirits which is relatively oder free and melts grease and oil residues right off better then any of the water based stuff, but isn't as noxious as stripper.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 09-03-2004, 03:35 AM
ghnat's Avatar
Thanks guys,
I think I will start with some mineral spirits. Soak it over night and then go from there. I guess gas would be next...
Greg Hnat
98 Jeep Cherokee
Old 09-03-2004, 07:35 AM
