Glen VW
Flagstaff_911SC's Avatar
Question 83SC CIS help needed
I recently replaced my fuel pump on my '83SC and had trouble getting it to start and run. It would start and within a few seconds would die, you could smell the fuel like it was flooded. After letting it sit for about a week, it seemed to correct it self. I got it to start, it really blew some black smoke for a few minutes and now the next problem:
Now (cold start) I can get it to start and idle but it is slow to rev and I can hear small backfires (I have a pop-off valve installed).
When the temp goes up after about 2 minutes of idling it will rev freely with no misses/hesitations but it will not idle. I can hold the rev's around 1000 rpm or so and give it gas and it seems to be fine though the rpm range but if I let off the throttle it will just die.
any suggestions on what to start looking at?
thanks
Old 09-04-2004, 06:36 PM
Somatic Negative Optimist
Gunter's Avatar
Is there a new check valve on the new pump? Accumulator getting old? If it does not settle down, a volume check for the pump and/or pressure settings check.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 09-04-2004, 07:13 PM
