AFR meter or Gunson ??
Hey all, figured I would toss this out. I'm looking for a device to measure the CO on my 78 SC. I don't have an O2 sensor so what I have is a basic CIS system. New 3.2 short stroke rebuild with nice new SSI's that I'm not willing to weld a bung to! I love the accuracy of the AFR that Wayne is selling but I think it might be over kill for me. The Gunson is +/- .5% and that seems a bit coarse. Any thoughts on which one to spring for?
Old 09-08-2004, 12:45 PM
Designer King
Paulporsche's Avatar
Do you need an exact number for emission tests? I can't tell where you are.
Another option is to have a mech w/ an analyzer set it for you (not expensive) and go from there. JW recommends 3.5%CO. There are lots of threads on settings.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-08-2004, 01:23 PM
I'm in NJ. No, it doesn't need to be super accurate for emissions..I'm exempt from that. Just a shop tool I guess. Not sure if the AFR meter is over kill for me [although I'm really getting into being a CIS expert} would hate to buy the gunson if it was more of a toy then a tool.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 09-08-2004, 02:07 PM
Designer King
I don't have one. There are other ways to determine what your mixture should be, as long as you don't need to know exactly what the number is.
Paul
Old 09-08-2004, 02:11 PM
Paul,
I've seen the thread on adjusting the CO by lifting the air sensor plate..how accurate is this method? I'm getting anal about my mixture because the last thing I want to do meltdown my big bucks rebuild.
Peace, Ron
www.ronorlando.net
Old 09-08-2004, 02:51 PM
Designer King
I have never done this, but some on the board have said that if you raise the plate and the revs rise then you can go richer. If you lower the plate and the revs rise then you can go leaner. If you raise and if you lower the plate and each time the revs drop, then you are done like Goldilocks.
Since I have owned my car for 15 yr I can tell when it is too rich or lean by things like engine note, tailpipe color, popping and how easily it revs.
Since this engine is effectively new to you, why not take it to a reputable shop and have it set per JW's 3.5% spec to be sure it is in the right ballpark. You can just leave it there knowing it is probably quite close.
If you're like me (see motto below) then you can monitor and try these other things later, if you feel comfortable with them.
Paul
Old 09-08-2004, 03:40 PM
Crotchety Old Bastard
RarlyL8's Avatar
I use both.
The Gunson gets you real close to where you need to be AT IDLE. The AFR meter lets you know what is happening in the entire RPM range.
Old 09-08-2004, 05:41 PM
I'll buy Wayne's LM if someone will buy my Gunson for about 70% of the price...............Bueller, Bueller, anyone, anyone..
Old 09-08-2004, 09:21 PM
I'll probably buy your Gunson. WHich one is is and what's the bottom line?
Thanks,
Brian
Brian
Old 10-06-2004, 09:11 PM
I measured my gunson against a shop 3 gas machine.. same reading.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-07-2004, 12:04 AM
Who is John Galt?
Rondinone's Avatar
This week I bought a single wire Bosch o2 sensor from advance for ~$18. The exhaust on a 911 is hot enough to heat it right at the tailpipe, so I shoved it in there and hooked a multimeter up to it. I've been fooling with my mixture based on drivability and sound, and the O2 sensor currently reads ~0.72V. I'll probably test it against my truck this weekend.
You need a good quality low impedence multimeter to read and O2 sensor. It won't tell you CO%, but it will give you an indication of lean or rich condition. If you're just interested in getting the mixture close to correct, this could be a cheap alternative.
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 10-07-2004, 10:07 AM
You need to place the sensore before the Cat to get accurate readings....
Warren & Ron, may you rest in Peace.
Old 10-07-2004, 10:35 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Works like a charm......After you pass smog
From a previous post:
"I found that every CIS engine has its particular 'happy place' where it likes to run. No two are exactly the same but CO% usually falls between 2-3.5%.
This can be set by ear and its very acurate for best performance. If tuning CIS w/ lambda, disconnect the O2 sensor first.
The trick to find your engines happy CO is to get the engine at least running and with the airbox cover and filter off, SLIGHTLY lift the air sensor plate via the exposed elbow with a finger, knuckle or whatever. All is needed is very slight pressure to notice any change in RPM. If the engine RPM increases it wants to be richened. This is also true if you were to pull down on the sensor plate. If RPM's increase, then it wants to be leaned out. Make very small adjustments with the 3mm allen as necessary. The trick is to get the engine at a max RPM so when you either push or pull on the sensor plate, the RPM's will drop (from either being too lean or rich)."
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 10-07-2004, 11:08 AM
Who is John Galt?
Rondinone's Avatar
Only if you have a cat...
'79 911sc Targa
'84 Tamiya Falcon
Old 10-07-2004, 01:53 PM
Virginia Rocks!
VaSteve's Avatar
I used Charlie's method and it worked well. I fine tuned with the Gunson I borrowed. The metal hose that comes with the Gunson would not fit inside the Cat Bung. I went to Home Depot and bought some copper tubing for hooking up an ice maker (I'm not kidding - 1/4" outer diameter) and stuck that in the bung. Worked like a charm.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 10-10-2004, 01:35 PM
which makes me think I could test carbs in 4th & 5th gear. I'd have a tube running into the cabin. I'd hold the rpms steady and that should give ballpark readings.. then I'll do a rolling dyno. cool
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-10-2004, 02:23 PM
