Send a message via AIM to jim912928
won't idle when "semi-cold"
Specifics: 1980 911SC Targa
When I first start the car it idles fine for a few minutes (cold start is good). While it is starting to warm up (like after 1/8th of a mile) it will immediately die when I put in the clutch (when stopping). After it is fully warmed up (20 minutes of driving) it idles just fine.
Any clues?
Jim
Jim
80 911SC Targa
75 914-6 3.2l Conversion
58 Triumph TR3A
07 Harley Night Rod Special, 08 buell 1125R, 08 Harley CVO Springer, 09 Harley Iron
Old 09-08-2004, 07:21 PM
Designer King
Paulporsche's Avatar
If you let the car warm up while idling (not driven) what happens? What rpm? If you depress the clutch what happens? If you give it some gas what happens?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-08-2004, 08:16 PM
Re: won't idle when "semi-cold"
Originally posted by jim912928
Any clues?
You need carbs.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-08-2004, 08:47 PM
I have not tried the warming up while idling..as it takes too long to get it warmed up enough to idle. When fully warm it idles at about 800-900 rpm. When dead on cold it's about the same (maybe a tad higher).
While it's in this "zone"...if i just keep alittle pressure on the gas peddle it will idle. It also "hunts" during this time if I have some pressure on the peddle...meaning the rpm's will flucuate up and down but won't idle steady.
On the what happens if I depress the clutch...assuming you mean standing still and not in gear...acts the same whether clutch is in or out.
Jim
Jim
80 911SC Targa
58 Triumph TR3A
Old 09-08-2004, 08:48 PM
Designer King
I think you are running too rich. Have you checked your CO w/ a gauge?
You can try leaning it 1/8 turn and see if the symptoms continue.
Let us know if this helps.
Paul
Old 09-08-2004, 08:52 PM
CIS probably needs an adjustment 'cause I assume ignition timing is ok. I think the warm start valve needs the psi adjustment. I forgot much of the CIS issues.
fwiw. cold starts at 60degF need about 2min at 1500rpm idle to reach about 175degF CHT. At around that temp combustion starts to become nice.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-08-2004, 09:03 PM
I'm traveling the next few days so I'll try some of this stuff this weekend...any other things I might try just let me know!
Jim
80 911SC Targa
58 Triumph TR3A
Old 09-08-2004, 09:12 PM
