Doesn't want/need a 3.6L
3.2 to 3.5L - It's finally started!!!
Well,
Summer is unofficially over in Southern California and it's now time to take the 3.2L motor out of the car for the performance rebuild. The motor has 88K on it and is being rebuilt due to one or more bad valve guides. Will know soon enough how many are bad (or even if the problem is the guides!!!). Car has intermittent blue smoke at idle (not start-up). Will go for a couple of weeks without smoking and than for a day or two spews blue clouds of smoke at a light. My guess is that the valve stem seal is moving around, which is why the smoke is so intermittent. Oil consumption is still 1,400 miles a quart which is acceptable. The car was on the dyno (Dynojet) today to get a baseline for the performance improvements to follow. With a Steve Wong chip, Dansk premuffler and Dansk 2 out muffler, the motor made 3 runs total. The first run saw 197 rwhp and the two subsequent runs saw 198 rwhp. All numbers were SAE corrected. Max torque was 182. Seems to be in the ballpark what other people are getting with the same/similar mods. Kudos to the gentlemen who got 219 rwhp with similar mods. I'm not even close but I guarantee I will surpass that with the new motor! We than took the motor out this afternoon, transported it to my buddie's machine shop and placed it on the engine stand. Tomorrow I will remove the exhaust, the Motronic injection and see how far I can get into the longblock. Bear in mind that my friend and I are doing this after hours. This will also take alot longer than normal because I am writing a series of articles for European Car Magazine detailing the build and options that are available to SC and Carrera owners. Basically every thing I do I have to stop and take pictures, both for possible publishing for the magazine as well as for my own documentation. What did we find while removing the motor? The first thing we noticed that will need replacing is the clutch slave cylinder. There is a small whole in the rubber boot that pisses fluid when squeezing it. Next thing I found is when the rear swaybar was being removed one of the rear swaybar mounts is beginning to crack. They are the original mounts as far as I know, but they are also the reinforced versions. Last, after removing the transaxle from the motor, it looks like the main seal is beginning to weep as well. Everything else external seems to be in good shape, we'll see what things look like internally in the next few days. The 3.5L motor has the following specs: 100mm Mahle Piston & Cylinders (MI/Carb Piston shape) 10:1 - 10.3:1 CR (goal) 993 Twin Plug Distributor with ANDIAL Motronic Signal Splitter ARP Head Studs ARP Rod Bolts Web Cam 20/21 Camshafts AASCO Performance Valve Springs Extrude Honed Intake Plenums Bored out Throttle Body Magnecore 8.5mm Twin Plug Wire Set Boattailed Engine Case Polished (not ported) Heads European Racing Headers by George Narbel Dansk 2 in 2 out Stainless Muffler Custom Steve Wong Chip for Twin-Ignition Hardware/Sheet Metal powdercoated, cad plated, etc, etc The motor is destined for street use with limited track days and thus will retain the std. Motronic and will run using our pathetic 91 octane available in California. Other than the headers (which the stock heat exchangers can easily be refitted in a couple of hours), the motor will be CA smog legal. The heat will be gone but the a/c will be retained (the wife will drive the car from time to time and she insists). I will post some pics from time to time as things progress but I also have an agreement with the magazine and thus they have first rights for publication. I can only post pics that won't be used for publication. Since the "before" and "after" dyno charts will be published, I can't post the "before" dyno graph from today. Since I am also doing this afterhours, I can't spend a bunch of time on the computer loading images. Posting progress for the most part will have to do. I know some of you are probably saying to yourselves why bother with a 3.5L from a 3.2L when you can just transplant a 3.6. The answer is two fold: I wanted the original engine case for the car and the cost for me to build this motor is WAY WAY less than sourcing a used 3.6L and conversion pieces. Thanks to European Car Magazine for helping to make this happen. Special thanks to Vision Motorsports in Laguna Hills, CA for dyno time, engine removal and storage of the car for the next few weeks/months. The goal for the project is 280 FLYWHEEL horsepower, or 238 rwhp if you use the 15% driveline loss that everyone seems to use. Why 280? Because with 3.5L, that is 80 horsepower per litre which is approximately what Porsche's most powerful street engines put out. The 87-89 Carrera only puts out 67.8, but the 2.7 RS puts out 77.78 and a 3.6 Varioram puts out 79.17. If I can get in the same ballpark as the latter two I will be quite pleased. Will provide plenty of punch even for my 2800 lb. Carrera. Will I get there??? Ralph |
Cool project!! Good luck and keep us posted!!
Cheers, Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Me like track days
Smart build sheet and great starting motor; I'd guess 250 at the rear wheels when she's all done!
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
re "Boattailed ... " I don't see the benefit for this spendy procedure. You are not going to run near redline very much ..... and you have a dry sump.
Here are some pics from today: On the dyno! Strapped down ready to go! El Pollo Loco lunch at Vision 3.2L ready to be removed On the ground! That's it for today, the thing is a grimey mess! Will have to spend some time in the engine bay cleaning everything up as well as making a nice bracket to hold the 2nd coil. |
Re: 3.2 to 3.5L - It's finally started!!!
same cams, 89911?
Pretty car, Ralph!
Andy |
Re: Re: 3.2 to 3.5L - It's finally started!!!
I really would love to change a couple of ratios but it is going to have to wait until next time. The transaxle is another "while you're in there" and a few ratios ends up being a diff (which I don't have) as well. Even with all of the "deals" and assistance from friends, my wife is still reading the riot act with respect to price. She thinks a car's purpose is to get from point A to point B. If she only knew how much this motor would cost if I drove into a shop and said "build this"... I'm trying to get the motor apart as quickly as possible to get everything out to where they need to go. Machine shop, powdercoaters, cad platers, polishers, etc. I figure 2-4 weeks to get the case, crank, rods, heads, etc back from Ollie's and than we can start to assemble the bottom end. In the meantime, plenty of time for cleaning. 2-3 hours per night 3-4 nights a week will have to suffice. One more pic to share: forget about my bucket of bolts in the foreground, check out the 935 conversion going on in the background. Didn't get any pics of Vision's 993TT and GT3 Cup car leaving for the NASA race at Sears Point though. Next time. Ralph |
Running 10.3 to 1 on 94 octane gas. I also used Ollie's for all my machine work. They came out perfect.
sounds like a great project - keep us posted.
Rich ![]() '86 coupe "there you are" |
Question:
Can you still consider going 3.4 instead of 3.5? I believe 3.4 will be a cylinder/pot "drop-in"...but a 3.5 requires machining the case. Enough of a difference to warrant the extra $ labor, etc ??? Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Besides, in my case, the Mahle 100's were about $500 cheaper than 98's for whatever reason. The 3.5L option is not for everyone and may not be the best choice for most people. The main drawback is the fact that once you bore the case spigots, you are committed to a 3.5L or 3.6L (using a C2 crank with piston mods). If anything is to go wrong, you can't remove the 100's and go back to stock 95's or 98's. With 98's, you can always go back to stock 95's if you have to. My worry is a few years down the road finding cylinders as Mahle is pretty much ceasing production on alot of different piston and cylinder sets. NASCAR is where they want to be and the Porsche market is miniscule for them even though they dominate it. Ralph |
Ralph |
Congratulations Ralph! I must say that I'm envious right now, and I can't wait to start work on my own motor. Of course that will be at least a year from now. See you on the 19th!
-Jon |
Thanks for the info on the 3.5 vs 3.4....
Might be interesting to others on knowing the options.... As to piston/cylinder sets.....you then may end up having to go to Cosworth....they even do individual units. Wil
Ralph-
I'm heading up to Ventura for the day on Sunday with a few friends (Bert will be with us). We will definitely be at the swap meet. Hope to see you there. -Jon |
Today's update:
Removed the exhaust system, which was surprisingly easy. The head/heat exchanger nuts were really rusty and I thought that they might pose a problem but a little liquid wrench (didn't sit for more than 30 seconds) and they came right off, no fuss. Than removed all of the outer sheet metal and got it ready for powdercoat. The Motronic system was next and that came off quite easily as well. I have alot of hoses to replace, as some of them don't look great and nows the time to do it. Than tackled getting the fan, alternator and fan shroud off which wasn't any big deal. The night ended with removing the cam oil lines and the chain housing covers. That is where I am at. About 2.5 hours of work tonight, not too bad. Just have a longblock staring at me now and I figure another 2-3 hours of work and everything will be completely apart. Ralph |
Designer King
Sounds like a great project. Good luck w/ it.
But..."Summer is unofficially over in Southern California" (!!!!!!!!!???????) ROFLMAO
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
