starting problem
when the car is cold it turns right over, after being driven and bringing the car to temp, if parked for more than ten minutes the car has problems starting the engine will crank but will take about 15 cranks to turn ove, any ideas? 79sc
Old 09-09-2004, 05:32 PM
LakeCleElum's Avatar
Check valve in your fuel pump or your accumulator....
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 09-09-2004, 05:40 PM
Designer King
Paulporsche's Avatar
Search hot start problems. It's usually the fuel accumulator or fuel pump check valve.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-09-2004, 05:41 PM
o
Old 09-10-2004, 06:55 PM
