Interior Lights. HELP!!!!!!!!!!!!!!!!!!
Hello everyone. I have my first self induced electrical issue with 87. I was playing with the glove compartment light. Then all the interior lights (glove box, both over head and trunk in addition to the radio) stop working. So I check the fuse, number 4 in the chart and is not burned. My question is; Am I missing a relay somewhere and if so where is it? And if there is no relay, what can be causing this problem? I tried turning all the switches to the off all the time position , and no luck. Any help will be greatly appreciated.
Thanks: Jose
Jose 87 Carrera ( Nougat Brown ), 11 Subaru Legacy (daily driver), 08 VW Passat wagon 2.0T (wife), 03 Audi A6 2.7T (sold) ), 98 Pathfinder (sold), 02 TT 225QT coupe (sold), 03 Audi A4 Avant (wife)GONE... |
Make Bruins Great Again
"When the problem is not where it should be, look where it shouldn't be". Check the other fuses. Also, just to be sure, replace the number 4 fuse anyway. If there is no change, you can always put the old one back in.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
