Tires
any suggestions on what tires to put on 15' fuchs for my 911t. 185/70/15 I believe. Want to put good tires on the car at a reasonable price. thanks
Old 09-09-2004, 10:09 PM
Designer King
Paulporsche's Avatar
Assuming you have 6", or 6 and 7" wheels and want to keep a period correct look, try Pirelli P6000, 195/65F and 215/60R. Go for the N designation which means they are approved by Porsche. I have them on my 77 body. They are very close to the dia of the original 185/70. They are not too noisyand have good wet and dry traction.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-10-2004, 06:58 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
The typical size for 6" rims is 205/60/15's or 205/55/15's (I'm running 60). Also do a search for tires.. you'll find endless discussions on brands
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 09-10-2004, 07:03 AM
Hoffman912's Avatar
sumitomos are not too bad, pretty stickey and cheep. not the best tire out there but a great bang for your buck.
http://www.tirerack.com/tires/sumitomo/sumitomo.jsp
Harry Hoffman
68' 912 Coupe 'Fritz' burgundy red (6808) | 67' 912 Coupe 'need parts?'
912 Registry charter member #912R0195-C | Early 911S Registry member #2070
http://hoffman912.blogspot.com/
Old 09-10-2004, 07:05 AM
You want some really good, sticky tires in 15" sizes? Toyo Proxes T1-S
www.edgeracing.com has about the best prices I've found. I have 4 of these on my miata (one of the few Hi-perf tires in my size) and they stick like glue.
http://www.toyo.com/tires/tire_specsheet.cfm?id=2
195/45R15 78V 241810 6.0-6.5-7.5 16.1 10.3 22.0 7.7 10.2 937 44 946
215/45R15 88VRD 241820 7.0-8.0 17.6 10.3 22.8 8.4 10.5 1234 44 913
195/50R15 82V 241930 5.5-6.0-7.0 17.4 10.3 22.7 7.8 10.5 1047 44 914
205/50R15 89VRD 241940 5.5-6.5-7.5 18.5 10.3 23.1 8.3 10.7 1278 44 899
225/50R15 91V 241950 6.0-7.0-8.0 20.3 10.3 23.9 9.0 11.0 1356 44 868
185/55R15 82V 242020 5.0-6.0-6.5 16.1 10.3 23.1 7.6 10.6 1047 44 900
195/55R15 85V 242030 5.5-6.0-7.0 16.5 10.3 23.5 7.9 10.8 1135 44 885
205/55R15 88V 242040 5.5-6.5-7.5 18.3 10.3 23.9 8.3 11.0 1235 44 868
If you want really, really sticky tires you may want to look into Falken Azenis Sports, they are inexpensive, come in a reduced tread depth, and are really sticky. Lots of people use them for wet track tires, but you wouldn't want to be driving in standing water or a torential downpour with them.
Old 09-10-2004, 07:59 AM
I use 15" Sumitomo HR200s on my SL and all have are good things to say about these tires....especially at $42 each.
At the time I ordered Tire Rack was the only distributor in the US.
Warren & Ron, may you rest in Peace.
Old 09-10-2004, 08:12 AM
