fred cook's Avatar
Cool Oil Hoses....How Long?.......
I am gathering bit and pieces to use to replace the trombone cooler on my SC with a Setrab oil cooler. Both line fittings are on the top of the oil cooler. I am going to use 90 degree AN12 fittings on the top of the cooler and metric to AN12 fittings on the end of the lines to the oil thermostat. Approximately how long will the connecting flex lines between the supply/return lines and the oil cooler need to be? I just want to make certain that I order enough braided hose to do the job.
Thanks,
Fred Cook
'80 911SC coupe
Old 09-10-2004, 09:44 AM
