Removing Shifter Trouble
Well I was going to change my bushings and coupler today but am unable to remove the shifter. All the 5 bolts are really torqued. Front 2 came out with a lot of effort. Got to one of the smaller in the back and it pretty much just stripped. I'm sure I had to be using the right size allen wrench. Any ideas how to remove a stripped allen bolt?
85' 911 Coupe sw chip, ghl sport cat, M&K sport muffler, short shift, magnecor wires, heat sheets, cool collar, Momo anatomic leather shift knob... |
Well all the big bolts are removed, but I think both the smaller are stripped. If I just drill the heads off will I just have to replace the shift rod bushing bracket?
Use a dremel to cut a slot in the top, then use an impact driver on em!
Cheers, Tim.
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD 1987 930 - SOLD 1983 911 SC Targa - SOLD http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else |
Driving member
I stripped one of mine when I removed my shifter for the same purpose. I found replacements at home depot.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
