Header - Oil line backdating ?
I have a 83 SC that I am installing headers ( European Racing) - it will be a track car. I just got my dual in dual out muffler and unless i am missing something it looks like I have to replace metal oil line ( one that wraps around rear of engine) - the right side ( passenger) header pipe extension lines up perfectly with the middle of the metal oil line.
Can someone confirm my fears. What parts do i need: ( I have a front oil cooler) c-107-739-10 & C-107-729-10 ( with front oil cooler) - pelican parts describes this as both w/ & w/o front oil cooler on the SSI page and in the desc.?? Or is it c-107-728-00? THanks Earl |
Earl:
Any pics of the headers? Thanks, J.P. |
Here is a pic of the headers w/o extensions and the oil line
you need to backdate the oil line. they sell them at pelicanparts. i actually asked the same question but i cant find my thread.
isaac 76 911 targa-project 91 ferrari 348-sold, broke my heart 73 vette convert-gone |
You need #1 911 107 739 10('73-74) and #2 911 107 729 10
Thanks everyone for the replies. Bill great diagram.
Just order the oil lines form our host. If you don't mind, two more questions. 1. Can I use heat in removing the current metal oil iine on the engine? It is org and clearly has not been removed. Started the ZEP treaments and will tackle removing thios weekend. Heat would be a great help, but not sure if safe. 2. The new oil on the engine, does this go on top or bottom of engine/trans?? I think I remember discussions about this? Thanks Earl |
Friend of Warren
Earl you can use heat, but I will be surprised if the nut is frozen where the line attaches to the engine.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Senior Member
I've got a flex line that runs over the tranny, and I've seen them before. Another option is to carefully bend the existing line upward, with the bend placed roughly at the center of the engine, under the pulley. It's the cheapskate method, but it has worked. Best method is to get the part from Pelican and do it right.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Just a quick update- Metal oil line off. I love ZEP!!! - Kurt you were correct no heat needed.
Nect is the oil line at the thermostat. Pelican shipped parts today ! thanks all earl |
Somatic Negative Optimist
Careful with the Thermostat, the nut will not come off easy. Recommend to cut the nut with a Dremel since it is scrap anyway. That way the Thermostat is not damaged.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
If you end up damaging the threads on the thermastat, there is a thermastat thread saver that works amazingly well. I am speaking from painfully personal experience
