beru distributor cap fails
got a cap from vertex (beru) cause it was a couple $ cheaper.
It lasted all of 100 miles. the carbon tip came loose from the spring. There's a center burn mark also that could have been the cause or the result of the tip comming off
I guess long story short, get the bosch.
Old 09-17-2004, 07:43 AM
they tend to fall out un-noticed as the cap is turned over to install it. once in place, if it stayed in there, the rotor would keep it from going anywhere.
206 637 4071
Old 09-17-2004, 08:13 AM
