The 9 Store
When I worked at the Porsche shop, I wasn't a tech but the ones who where used to hit the cap with a hammer on angle and knock it off with a couple hits. One tool, 10 seconds, done.
All used parts sold as is. |
Chisel with a big f’n hammer and it came right off with minimal damage to the cap.
Putty knife. Tap it around to break the seal. Walk the knife around to twist it out. I use a rubber mallet.
Targa_PB_78_SC
Maybe all these fine ideas work, I don't know. Years ago (30 maybe more) I did my first wheel bearing grease job. I got this tool and have been very pleased with it many times.
![]() Tighten the jaws on the grooves in the cap, add the long bar and my slide hammer and its off in a few slides.
BareRearedRookie |
as mepstein said all you need is a hammer..but the best is this one..have been using it since the 1980`s..;-) use the thinner side of it,,works just perfect...
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
'87 Targa
Lots of ways. Some more "professional" than others.
This works perfectly well for me. small stick of wood and hammer: strike (light tap), rotate, strike, rotate, ... takes maybe 5 taps.
Targa_PB_78_SC
So you could have saved me many dollars had I known this more than 30 years ago .I end up hitting places I don't want to now when I swing a hammer (like my wrist or my thumb) . Now I'm sticking with my method.Mike
BareRearedRookie |
I cut down a 2" piping riser clamp, welded in parts of two Ubolts. Two pry bars on the ears of the riser clamp and they slide off. Less than $15 in parts.
Registered Minimalist
We need another 5 pages on this subject.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Don't know if anybody else already posted this...pretty easy when you know how
![]() https://youtu.be/9QcqqoDh2io?t=105 Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
Counterclockwise?
I just use my bigass channel locks.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Lots of good ideas in this thread, just adding the one that worked for me - a medium-sized welding clamp.
Last year when I rebuilt my front end, new car to me, I had a terrible time getting them off. I think it was the first time they had ever been removed. 42 years… I used a muffler clamp to get hold of the cap and pried it out. I like Spetrow’ tool, but I’ll try Thorndyke’s next time… If i’m still alive. 😊
