struts
Hi guys,can I use early hubs and rotors on '84 struts.I know the caliper spacing is wider but thats it,thanks,T.C.
I would rather be driving
Yes as long as they are not turbo hubs. Actually, the turbo hubs will fit but will have the wrong offset. Why would you want to? Teh 84 Carrera has bigger brake rotors (20 vs 24mm) and the early ones will not work properly unless matched by teh earlier brake caliper.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
