HELP! 3.6 conversion No Spark now what?
After almost 2 months of waiting and spending the hard earned
$$$ I put oil in the tank made sure all connections were made and turned the key over, and over, and over. Nothing happend except the engine cranking and building oil pressure via the guage but nothing else. I am getting fuel because I hear the pump running. What now? Could it be the DME? I am getting voltage to the twin coils with the key on. Frustrated and confused...
Ryan Cimarron region PCA member 98 Boxster |
Senior Member
Connections on the distributors and engine wiring harness good and solid? They can get loose on the engine harness at times and cause problems.
About 3 days behind your situation. Hope to add oil and see if there is any spark this coming week. JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
I have checked and rechecked and cant figure it out?
bout at the end of my rope not sure what to do next
Have you made sure that the switched connection(for DME) at the fuse panel is getting power when the ignition is in the full on position, and still gets juice while it's cranking.
Make sure the speed\ref sensor on the flywheel is the correct distance from the flywheel.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
I have not checked the switched power when cranking...
I set the distance of the reference sensor when installed the tranny which was set at 1.0 MM is this right for a 95 993 engine?
I checked the voltage and it is not getting power when I
crank the engine. I am going to change the source to one that does and try again...
Changed the switched lead and....
VROOMM!!! Fired off on first try. A big THANKS to all of those on the board who have given input on my conversion. I could not have done it without your help. I partially dismantled the car to get ready to paint it week after next. I cant wait to get it on the road. I am running just the cat and man is it loud. I LOVE IT! More pics coming soon...
Hi Warspd. 1.0 is correct on the reference sensor. Also make certain that the accelerator cable is opening the throttle fully. Dan
I have plenty of lead for my pencil... just not enough paper to write on.. 82SC with 95 993 engine 2004 Ford Powerstroke |
Senior Member
Ok guys,
Hate to hijack this thread but its on the same subject and recent and hope someone can help with this? I finished up the final wiring on the car and tried to start it. Turns over well until the battery told me it had not been used in a while. Its on the charger now and will be topped up tomorrow. Turned it over until I got good oil pressure and then replaced the DME fuel pump relay. Tried to start it and get a fairly good whiff of fuel in the exhaust outlet but not even a hint of its trying to start. This is a 3.6 that was in Bill Verburgs old SC. Was set up and running, just pulled to make way for a bigger engine. Everything had been sorted while it was in his car so I would hope that its nothing like the sensor distances. I have good voltage on the fuel pump wire. Get 11v when I go to start so feel that the fuel pump has voltage. Due to the smell I feel that the fuel is getting to the cylinders. Its got a PMS harness going from the DME computer/fuel relay to the front. All the wires are making good connection and have power when the switch is turned on. The damm connection to the tach is a bear and hope its making contact but do not believe that this would stop it from firing?? Where do I start to check for spark? Nothing at the plugs right now but what is a good proceedure to work backwards? TIA, Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB Last edited by Joeaksa; 09-22-2004 at 05:25 PM.. |
Check for the same problem that warpspeed had. No power while cranking. Certain circuits in a 911 have power with the key on, but none while the engine is cranking. If you hooked into this circuit there will be no power for the DME and of course no spark is the result
Pete |
I had to check for +12 volts when the engine was cranking and it had none so what I had to do was wire the lead right into
the ignition switch where I was getting the 12 volts with it cranking and boom it started right up...
Senior Member
Ryan,
Which wire or circuit needed the 12v only during cranking? I had a discussion with PMS about the hookup as their new instructions said to hook one wire up to constant 12v direct to the battery, another to switched 12v and a third to switched 12v min 10 amp. Turns out that they had gotten the wording wrong in the updated instructions and the "second" 12v connection was not switched but a constant 12v. Any chance that the tach or oil temp connections could be causing problems or are the wires from the new harness to the gauges just to make the gauges move? Thx, Joe
I had the same symptoms when the lead to the DME to the battery power had a bad connection. The motor would crank, and I got spark everywhere but wouldn't fire. You should be able to crank it up and start it without the guages wired. I used a wiring harness out of a 93 and that was my finding.
Senior Member
Paul,
Thanks very much. I soldered every connection where able but will check the DME power lead again. Getting to the back of the oil pressure gauge was not hard but the tach has a large moulded plug (not a single spade connector) so its not easy to get to the "sense" wire. Was hoping that a bad connection there was not the issue. Will head back down to the shop and start checking somemore! Thanks, Joe
Joe
You need a 12 V constant source, usually hooked direct to the battery. You also need a switched 12V source that keeps power during cranking, as noted above when picked up off the fuse panel several of the 12V sources that have power in run, don't have 12V during cranking Also check your DME relay, it is a 2 pole relay, the first side closes when the key is turned on, this provides power to coils and other 12V components on the motor (idle valve etc). The second side closes when the DME senses engine rotation via the flywheel sensor. If rotation is sensed then the DME sends a ground to the other side of the DME relay, closing it and firing up the fuel pump. The realy can be heard or felt to click when the key is first turned and again during cranking if that is functioning OK. Also take a look at Ingo's page for a nice wiring diagram for the conversion harness. Todd
1989 911 Targa |
Senior Member
Todd,
Thanks and was trying to find Ingo's website but its been changed. Will hunt up some of his recent posts and see if its there. Edit: just found his site and its still blocked. Sent Ingo a PM and hope to get this figured out someday! Thx, Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB Last edited by Joeaksa; 09-23-2004 at 11:46 AM.. |
Some snipits from posts I have made about this in the past
The DME relay should get a switched power source that is present during cranking that goes to term 86 on the DME relay. This same switched 12V source goes to term 2 of the 6 pin plug on the 964 dme harness Fuel pump should get power from DME relay term 87b during cranking, this also provides 12 V to term 5 on the 964 14 pin plug on the DME harness. As I stated I don't know without looking at the 993 wiring diagrams how this translates to a 993 swap but it should give you an idea where to look. If your flywheel sensor is set up properly and sensing engine rotation the wire going to DME relay term 85b should go to ground with engine rotation. Your DME relay needs 2 sources of power, term 30 should have voltage direct from the battery (best idea is to use a fused link and run a line straight from battery + to term 30 on relay) other is the switched 12 V source to the DME relay term 86 (mentioned above) that must have 12 V during cranking, this is usually picked up off the fuse panel in the trunk once you verify it is a circut with power during starting. You need to check terminal 87b not 87, there are two 12 V out terminals on the DME relay. When you turn the car on you should hear the first pole of the DME relay close, when cranking the second pole should close. If the wire to 85b is going to ground with engine rotation and term 86 has power when cranking you most likely have a bad DME relay If you can't find Ingo's site, I can get you a copy of the harness diagram and send it to you tomorrow. Todd
1989 911 Targa |
Senior Member
Todd,
Thanks very much for the help. Am heading out the door to work on the car right now. Let me take some measurements with the VOM and get back to you tonight. I found Ingo's website that was listed on his Pelican parts profile (http://sswl.di.com/~ingo)but its blocked for anyone to view. Emailed him to ask if its up on another site. Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB Last edited by Joeaksa; 09-23-2004 at 12:07 PM.. |
Here are Ingos wiring diagrams
